mTDI Mechanical TDI Conversions
CJAA Conversion?
Topic: CJAA Conversion? (Read 7991 times)
May 14, 2021, 01:28:29 pm
Bad Actual
CJAA Conversion?
May 14, 2021, 01:28:29 pm »
I've got a couple Jetta's that I'd like to pull the CR TDI's from, convert them to mTDI's with all mechanical control for the turbos. Has anyone done this yet?
May 14, 2021, 10:13:27 pm
Re: CJAA Conversion?
May 14, 2021, 10:13:27 pm »
I do not think that anyone has done an mTDI CR yet. I've considered it. It would require a fair amount of custom work but I believe would actually be doable. The way I would do it is use the ALH accessory bracket, use a custom intake manifold, and make whatever adapters were necessary to fit fully mechanical injectors.
May 18, 2021, 11:55:45 am
Bad Actual
May 18, 2021, 11:55:45 am »
I have two of these, one running, one is not (pulled from a wreck). I don't have a problem pulliing together the parts to test out fitments, etc. Let me get the ugly one on a stand first and start getting some meaningfull measurements, pics, videos put together.
- Would not one of the pumps for a 1.9 work, with some larger injectors?
- Can I control how rich/lean the mixture runs via cable/lever? (Like aviation mixtures) I hit lots of mountains (Is it even necessary?)
May 18, 2021, 01:51:00 pm
May 18, 2021, 01:51:00 pm »
If the ALH bracket will bolt up (and it looks like it will) then getting a pump that would work well is quite easy. The AAZ pumps would not be a good choice. There are others that would be much better, e.g. Land Rover 300TDI, LT28, Cummins 4BTA, etc... Injectors that fit and work is a much larger hurdle.
May 18, 2021, 01:52:07 pm
May 18, 2021, 01:52:07 pm »
...and the injection pump IS the mixture control. Thinking of it as rich/lean on a diesel is not really helpful, though, IMO.
January 17, 2022, 01:29:10 pm
Chuck1978
January 17, 2022, 01:29:10 pm »
https://youtu.be/DeZXeo-qnzA
DONE!
H Pump.
"Jhon Doe"
He's in Europe somewhere.
January 17, 2022, 06:28:40 pm
Moderator
4552
January 17, 2022, 06:28:40 pm »
Flames out the exhaust ports!!!! You will need to watch the EGT gauge for sure.
CJAA Conversion?
