Author Topic: 4bt or rover pump  (Read 5818 times)
November 24, 2016, 05:20:55 pm
Ian0391
  • 119
4bt or rover pump
« on: November 24, 2016, 05:20:55 pm »
Hey guys,
I had a compound turbo aaz built up using a k14 and t4oe that ripped but ended up blowing the motor up. I managed to find an almost new 1z block and head so I'm going to try to build up an mtdi and use my compound turbo setup. I'm looking to make in the area of 200hp. Is the rover pump capable of that or should I start with a 4bt pump.
Sent from my SM-G920W8 using Tapatalk
Reply #1November 27, 2016, 08:45:44 pm
Re: 4bt or rover pump
« Reply #1 on: November 27, 2016, 08:45:44 pm »
Rover pump can do that fine. It'll handle higher RPMs than the BT pump will and has a more appropriate advance curve.
Reply #2June 29, 2017, 07:44:45 pm
ketchupshirt88
  • 3
« Reply #2 on: June 29, 2017, 07:44:45 pm »
on the other end of the spectrum, is a franken-pump built from an AAZ pump and 10mm TDI guts able to hit ~180-200hp?  hardware will be an HE221 and race 520 nozzles on a 1Z.  currently computer controlled but the chips weren't written for that hardware and i don't want to deal with any of the ECU tuners anymore.
i know that a rover pump is considered the best option now-a-days because not much needs to be done for them to work well, but i missed out on a rover pump for $350 shipped to me... still hoping another cheap one will come up soon...  But i already have several 10mm TDI pumps for parts (most of them ran when pulled but leaked badly) as well as one AAZ pump and one 1.6 n/a pump.
Im over on TDIclub, PM me there if you ever wanna get ahold of me. I rarely post here, but i visit here to browse the M-TDI stuff and waste-gated turbo stuff because TDIclub is all "VNTXXXX this and Stage 3 tune that"... LOL
Reply #3June 30, 2017, 09:00:15 am
« Reply #3 on: June 30, 2017, 09:00:15 am »
There's a post on here somewhere detailing the modifications needed - you'll need to do some welding and fabrication but yeah, you can make a suitable pump. Trying for higher horsepower levels with a smaller plunger isn't the best thing in the world though - you'll have a longer injection duration which is harder on the engine.
