General Information
General
Ultimate winter mode? Problems and solutions..., also, in cab heater anyone?
Pages:
4
Topic: Ultimate winter mode? Problems and solutions..., also, in cab heater anyone? (Read 18776 times)
Reply #30
January 14, 2014, 06:45:01 pm
shorttimer
Re: Ultimate winter mode? Problems and solutions..., also, in cab heater anyone?
Reply #30 on:
January 14, 2014, 06:45:01 pm »
What's winter? It was 80 today.
Reply #31
January 15, 2014, 06:59:32 pm
Enslaved_Pickle
User+
Reply #31 on:
January 15, 2014, 06:59:32 pm »
I took the tensioner arm out today and inspected it and the bushing. They are both fine, no play and no grinded down arm. I re-greased the crap out of it and made sure the pulley spun freely. Threw it all back together and started the car,..... It still squeaks
its slightly quieter but still there. Any other ideas?
Mk3 1.9L turbo diesel rat
Reply #32
January 15, 2014, 07:14:25 pm
Reply #32 on:
January 15, 2014, 07:14:25 pm »
My tensioner looked fine and the pulley spun freely. I replaced it and the noise stopped immediately. If it got quieter after greasing I would still guess that is your issue, you probably just need new.
Round 2
Reply #33
April 01, 2014, 05:15:50 am
Enslaved_Pickle
User+
Reply #33 on:
April 01, 2014, 05:15:50 am »
Soooo, the squeaking has gotten much worse, it appears that the crank pulley is wobbling more than it was when i bout the car.
I have removed the factory crank bolt and inspected the keyway and there was no signs of wear. I bought a new crank bolt, covered it in red locktite and torqued it correctly. I have also marked a line across the bolt and the sprocket so i would know if it started to loosen.
So now i've replaced
- crank pulley
- crank sprocket bolt
- tensioner and pulley
- 3 different serp belts
the bolt has not moved at all, i'm ready to throw my rusty 1.6na in just to stop the squeaking
Any ideas?
Reply #34
April 01, 2014, 05:18:59 am
Reply #34 on:
April 01, 2014, 05:18:59 am »
did you get a new tensioner, or did you only grease it and reinstall it?
Again, mine looked fine and felt fine, but when I put the new one on all the noise went away.
Round 2
Reply #35
April 03, 2014, 03:52:29 pm
Enslaved_Pickle
User+
Reply #35 on:
April 03, 2014, 03:52:29 pm »
Did you get your parts online? I called the dealer today and they can't get the bushings or the tensioner arm
Reply #36
April 03, 2014, 03:57:39 pm
Reply #36 on:
April 03, 2014, 03:57:39 pm »
http://www.idparts.com/catalog/product_info.php?cPath=29_90&products_id=629
Yes, I did, but mine is MKIV. I don't know if the tensioners are the same, but I do know mine stopped immediately after replacing. I even talked about it to my mechanic friend and he thought it was so bad that the bearing or clutched pulley was going out of the alt and I should start saving for that. But when I replaced the arm and the entire deal the noise went away completely.
Round 2
Reply #37
April 04, 2014, 05:44:17 am
srgtlord
Reply #37 on:
April 04, 2014, 05:44:17 am »
Here is the link to the parts you need for the vw A3 serpentine setup
http://www.idparts.com/catalog/index.php?cPath=29_90&filter_sess_make=Volkswagen&filter_sess_year=1996&filter_sess_vehicle=15
Reply #38
April 04, 2014, 06:21:23 am
Reply #38 on:
April 04, 2014, 06:21:23 am »
That doesn't have the new arm and all the bushings that I could see. That is why I didn't post that for him. I think the problem is in the pivot of the arm when under all that tension.
Round 2
Reply #39
April 04, 2014, 08:02:54 am
Reply #39 on:
April 04, 2014, 08:02:54 am »
I see both an arm and the bushings on that link, even the seals for the arm?
Reply #40
April 04, 2014, 02:03:17 pm
Reply #40 on:
April 04, 2014, 02:03:17 pm »
My bad, I missed that arm before ...2x
Round 2
Reply #41
April 29, 2014, 05:54:21 pm
Enslaved_Pickle
User+
Reply #41 on:
April 29, 2014, 05:54:21 pm »
Alright, i'm officially done, if the next thing i do doesn't get the squeak to stop i'm parting out the car.
I changed the tensioner, the tensioner arm and both bushings yesterday with new oem vw parts and it still squeaks!!!!
Anyone want an aaz?
Reply #42
April 29, 2014, 06:17:04 pm
Re:
Reply #42 on:
April 29, 2014, 06:17:04 pm »
Have you tried using a mechanics stethoscope to narrow down the source of the squeak?
Reply #43
April 29, 2014, 09:28:14 pm
srgtlord
Reply #43 on:
April 29, 2014, 09:28:14 pm »
maybe its the alternator? Or the harmonic balancer?
Reply #44
April 29, 2014, 09:40:56 pm
Enslaved_Pickle
User+
Reply #44 on:
April 29, 2014, 09:40:56 pm »
Already swapped alternators and harmonic balancer is new
Pages:
4
General Information
General
