Author Topic: Temp Sending Unit/Question  (Read 1905 times)
June 28, 2013, 02:01:45 pm
ein bora
  • 377
« on: June 28, 2013, 02:01:45 pm »
This is the one that fit's into the rad, can you buy these with different pre-set values, or is what you have - what you get?
I'm using the passat's rad in my b5 gas to idi diesel conversion but I think it may be on the high side and I would feel better if it ran a bit cooler.
Any help appreciated. Thanks.
« Last Edit: June 28, 2013, 05:19:30 pm by ein bora »
If you can't take advice - then you can't be helped!
Reply #1June 28, 2013, 02:47:28 pm
Re: Temp Sending Unit/Question
« Reply #1 on: June 28, 2013, 02:47:28 pm »
Is it the big screw in kind? if so, Saab used 2 per car in the late 80s, a high and low.
Reply #2June 28, 2013, 07:56:55 pm
« Reply #2 on: June 28, 2013, 07:56:55 pm »
waler (sp??)  has high/lower temp ones...
old 1 speed style come in 75*c 82*c and 92*c   92 was common... 82 was for 80*c thermostat.. and the other is for the 72*c they also sell...
ive seen the mk2/mk3 duel sped opnes, 3 wire also in the standard 2 range, think its 92c and 96c..  and a lower range too!! but cannot rember its range...
i would wire it up so high speed kicks on 1st... swap the 2 pins in switch.. and then search forwhat you seek with that temp mod...
