engine rebuild 2 yrs ago: prestart/break-in procedure?
Topic: engine rebuild 2 yrs ago: prestart/break-in procedure? (Read 2110 times)
June 23, 2013, 07:37:08 pm
Rock3tman
prev: 60typ2, 68pickup, 79rabbitD. now: 83jettaTD
June 23, 2013, 07:37:08 pm »
The engine has been in a 60 degree, dry, heated garage for two years. bearings, cam, etc, well lubed, bores dry. Will I have rust on the bores?
pre-oil suggestions? yes, I'm slow (and old) thanks in advance.
June 23, 2013, 09:26:14 pm
Moderator
4552
Re: engine rebuild 2 yrs ago: prestart/break-in procedure?
June 23, 2013, 09:26:14 pm »
Given your location I might suspect it but in a heated garage? Likely not. Still you can be on the safe side and pull the glows and give it some WD 40 and and a squirt of oil and turn the engine over by hand for awhile with the glows out. Can't think that will hurt it.
