Turbo converted polo 1.4d(n/a) (1W) with video´s
Pages:
5
6
7
8
9
Topic: Turbo converted polo 1.4d(n/a) (1W) with video´s (Read 66735 times)
Reply #105
October 09, 2011, 01:50:26 pm
polo_td
Re: Turbo converted polo 1.4d(n/a) (1W) with video´s
Reply #105 on:
October 09, 2011, 01:50:26 pm »
thomas
Reply #106
January 18, 2012, 12:48:31 am
polo_td
Reply #106 on:
January 18, 2012, 12:48:31 am »
new pic.
Thomas
Reply #107
January 18, 2012, 08:35:48 am
Reply #107 on:
January 18, 2012, 08:35:48 am »
still looks like the intercooler is just sitting there un hooked..
once you go to hook that thing up, i hope you clean it out..
sweet car tho!
Reply #108
January 18, 2012, 12:35:38 pm
polo_td
Reply #108 on:
January 18, 2012, 12:35:38 pm »
im sorry but your vision fail you, the ic is connected and working ok.
Thomas
Reply #109
January 18, 2012, 01:43:56 pm
carrizog60
Reply #109 on:
January 18, 2012, 01:43:56 pm »
time for wider wheels?
Portugal
Reply #110
January 18, 2012, 09:24:01 pm
polo_td
Reply #110 on:
January 18, 2012, 09:24:01 pm »
hi.
yes at the rear at least.
Not so easy to find wheels/rims with an ET below 20 though.
But i´m looking out for it.
Thomas
Reply #111
January 19, 2012, 05:17:35 am
carrizog60
Reply #111 on:
January 19, 2012, 05:17:35 am »
check ebay.de, there as plenty some times.
or go widened steelies,i have those in my passat,no problems on changing ET´s there
Portugal
Reply #112
December 27, 2012, 05:25:13 am
polo_td
Reply #112 on:
December 27, 2012, 05:25:13 am »
I´ts been a while sins the last update but better late then never ...
Now, the chassi update has begun.
first we dissmounted all at the rear, beam wishbone etc.
Empty...
It´s always more work..
On this pic, you can see two other taction arms that we was thingking of using but no, we will make a new set with unibolts...
time to start up the lathe, had to produce this..
Can anyone see what this is?
When we found the rigth pivot point for the rear beam, I could start with the front end.
Then to the fun parts. :)Rear beam modification.
We will build a trailingarm setup.
Man in action....
One done .
Did make a new set of shorter steering arms.
These will give us quicker steering respons.
Thomas
Reply #113
December 27, 2012, 08:35:33 am
Reply #113 on:
December 27, 2012, 08:35:33 am »
i don't understand quite what you are doing but i expect to see nothing but quality like the rest of the build
Reply #114
December 27, 2012, 01:32:15 pm
Reply #114 on:
December 27, 2012, 01:32:15 pm »
looks like he cut up an old torsion beam, and converted it into IRS?
Reply #115
December 28, 2012, 01:09:29 pm
justiz00
Reply #115 on:
December 28, 2012, 01:09:29 pm »
Swaybar as a strut rod, similar to the superbeetles. I know nothing about the polo but keep up the good work!!
Reply #116
December 28, 2012, 02:32:46 pm
carrizog60
Reply #116 on:
December 28, 2012, 02:32:46 pm »
would it be needed?
does berg cup mk1 have oem rear bem?
i know that my g60 mk2 handles pretty good,no irs is needed for me...
polo_td:
i have strated a topic about pump mods after seeing what was done in your pump,can you take a look and help to clarify some things?
thanks and keep up the good work!
greetings from portugal!
Last Edit: December 28, 2012, 02:38:47 pm by carrizog60
Portugal
Reply #117
January 03, 2013, 03:17:13 am
polo_td
Reply #117 on:
January 03, 2013, 03:17:13 am »
Hi.
Its the center line pivot point bracket for the rear beam.
IRS on a Polo 86c is far beyond the normal mods.
The front and rear beam are now done and mounted
Fully adjustable in front and rear.
Today we will start with the front hub angle.We want the wheel to dive in more when we turn the steering wheel.
The berg cup cars have no irs thats for sure.
But i want to have control over the toe-travel, have the possibilities to adjust camber ,caster and toe.
So far the setup has changed the wheelbase with ~50mm in length and the track width by 60mm.
Caster in front 3deg. so we will see what we end up with but it will definite mean that we have a better situation then before.
pics coming up.
stay tuned....
Reply #118
January 03, 2013, 04:45:18 am
akuma406
Reply #118 on:
January 03, 2013, 04:45:18 am »
Congratulations for the great job that fact.
I'm shocked at what has accomplished, and spend more than 2bar of pressure without breaking engine is impressive.
Reply #119
January 07, 2013, 04:17:26 am
polo_td
Reply #119 on:
January 07, 2013, 04:17:26 am »
Thank you for the comments.
The engine is fantastic as it is just now.
But i will add water / meth injection towards the sommer.
now back to the update of the build so far.
Now comes the pictures.
After a whole lot of work during the Christmas and New Year eve, now the car is down on its own wheels again.
First a picture of the modified section of the section toward the torpedowall to handle the increased load.
Then comes a picture of the rear axle mount in the middle.
Wishbones have been modified.
The spring plate is moved up 20mm, a stabilizer bracket is welded and steering arm has a new position. The angle of the hub modified to provide more angle in the hub that little sloppy expressed as more camber angle and better precipitation of the wheel when steering.
Finally a picture of what the front end looks now
Thomas
Pages:
5
6
7
8
9
