Author Topic: help with starting  (Read 2401 times)
June 08, 2009, 08:58:43 pm
allsierra123
help with starting
« on: June 08, 2009, 08:58:43 pm »
I have been trying to start my aaz. No such luck it just cranks good for a second and then it acts like the battery dies as it slowly slows cranking speed. I have kept the battery charged taking it an tested it Also and made sure it was fully charged before cranking. It does the same thing. Its the stock battery I used before the diesel conversion. The starter seems to be working fine Its the stock auto starter as well. Anyone have any Ideas what might be happening?
Reply #1June 09, 2009, 04:28:02 am
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
Re: help with starting
« Reply #1 on: June 09, 2009, 04:28:02 am »
Off chance, but are all related electrical terminals, grounds, etc. squeaky, shiny clean & tight?
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #2June 09, 2009, 04:30:14 am
maxfax
  • 2126
« Reply #2 on: June 09, 2009, 04:30:14 am »
You mention stock auto starter..   Is this a gasser starter as well???
Reply #3June 09, 2009, 04:36:03 am
lovinthedeez
  • 489
« Reply #3 on: June 09, 2009, 04:36:03 am »
 if it is, your diesel wants more cranking speed to start it.  gas compression 150 ish.  that aaz.....400 ish
Reply #4June 09, 2009, 04:52:52 am
carrizog60
  • 978
« Reply #4 on: June 09, 2009, 04:52:52 am »
need a more powerfull battery and starter :)
Portugal
Reply #5June 09, 2009, 05:22:22 am
arb
« Reply #5 on: June 09, 2009, 05:22:22 am »
cranking speed is critical to starting out car when it is cold. If you have slow speed, its usually a bad cable - ground maybe, or the starter. Only the diesel will have the power as others have said. If you have a diesel starter, it could have worn brushes / commutator..  You could push / pull start if you have a manual. A steep hill works great !
Reply #6June 09, 2009, 07:55:29 am
allsierra123
« Reply #6 on: June 09, 2009, 07:55:29 am »
Yeah its the gasser auto starter.
Reply #7June 09, 2009, 08:04:16 am
allsierra123
« Reply #7 on: June 09, 2009, 08:04:16 am »
Yeah the battery Is still there. Its new and the wiring looks good not corroded or anything. wasnt there an adapter To go to the TDI starter. There wasnt an auto diesel starter was there?
