Author Topic: Power steering oil seal source  (Read 2177 times)
June 07, 2009, 11:18:24 pm
Torchd
  • 372
« on: June 07, 2009, 11:18:24 pm »
Hey guys...
Power steering oil seal on my car's steering rack is leaking. Would any one know a good source to get one from? Its where the lower drive shaft connects onto the rack.
Cheers
Reply #1June 07, 2009, 11:18:52 pm
Torchd
  • 372
Re: Power steering oil seal source
« Reply #1 on: June 07, 2009, 11:18:52 pm »
car is am MKIII 95 RHD aaz.
Reply #2June 08, 2009, 02:07:09 am
Ziptar
  • 565
« Reply #2 on: June 08, 2009, 02:07:09 am »
For lack of a seal, if the leak is not too bad try some Mobil 1 Synthetic ATF as P/S Fluid. I had an Audi 200 Quattro that leaked the expensive mineral oil and wasn't loooking forward to swapping the rack. I had read a few posts on an Audi board about the Mobil-1 working well and swelling seals enough to stop leaks. I figured I had nothing to loose, it worked.
I did the same flush and fill in my Jetta 1.5 years ago and it works great. I had a tiny drip, it cleared up in a week, ~$5.00 and allot less labor.
It is easy to do, and you shouldn't need more than a quart to flush and fill it.
Drain out the mineral oil and put the discharge hose in a bucket.
Turn the wheel lock to lock a few times to get old oil out.
Put the intake line in a small can of ATF.
Turn the wheel lock to lock a few times to flush the rack.
Re-assemble.
File the reservoir with ATF.
