Author Topic: A New Thought on my Cold starting/Inconsistant running Problems  (Read 1917 times)
June 06, 2009, 09:58:07 pm
boosted_diesel_84
  • 216
so, after my build the car is very hard to start cold, lots of missing and white smoke, and should run a lot better than it does for whats all done to it, i had GTD nozzles installed from a GM mechanic i know, he popped tested them, but i kno he didnt adjust any of them, or none were sanded down/lapped, and there was a good chance dirt got in them from sitting in the garage for a few months, could this have anything to do with my issues? thanks for info
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #1June 07, 2009, 01:13:39 am
Re: A New Thought on my Cold starting/Inconsistant running Problems
« Reply #1 on: June 07, 2009, 01:13:39 am »
Dirt is very bad for injectors.
