Author Topic: Starting a turbo build...Videos of it running :D  (Read 147434 times)
Reply #150May 10, 2010, 09:02:00 pm
Re: Starting a turbo build and...
« Reply #150 on: May 10, 2010, 09:02:00 pm »
Thanks for the info. The mount insert above says that it is just to stiffen a little, not like a solid. I just want a little life out of it. I suppose that mount isn't too bad to unbolt from the engine if I don't like stock.
Reply #151May 10, 2010, 10:01:14 pm
mystery3
  • 774
« Reply #151 on: May 10, 2010, 10:01:14 pm »
I have the inserts on driver and passenger side of my caddy, they vibrate significantly more than worn out old rubber mounts but no where near the level that solid mounts would vibrate. Solid mounts on a diesel would be insane my neon had a solid front mount and transmission mount it was bearable but that motor is silk compared to these 1.6L's. I did notice improved throttle response with the inserts and I like rattly stuff, I actually know when the car is running or not running!
Reply #152May 16, 2010, 07:19:29 pm
« Reply #152 on: May 16, 2010, 07:19:29 pm »
I am trying to mock up the oil lines, downpipe, and block breather. Basically anything that might fight me when in the car. I am making a support for the DP off of the block, so the flex does its job instead of putting undue strain on the tubing itself. I hope this is a good idea.
Reply #153May 16, 2010, 10:00:02 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #153 on: May 16, 2010, 10:00:02 pm »
OOOOH! SOFT CORE :o nice work, looks very clean.
you know, decarbonated beer is a better coolant than the stuff you buy at the auto store, and is better for you...... really
"If the boost were to rise then the throttle would remain in the wide-open throttle position, which might be fun, but probably not for long"Libbypapa
Reply #154May 22, 2010, 09:45:59 pm
« Reply #154 on: May 22, 2010, 09:45:59 pm »
Pic loaded.
I am pretty proud as I haven't ever done anything like this before. Special thanks to Dakotakid for the fender that made this possible.
and this is some stuff that Gee-Bee sent for me to do the heater box. Great feeling stuff.
Reply #155May 23, 2010, 06:39:14 am
« Reply #155 on: May 23, 2010, 06:39:14 am »
I like it.
I think your brace idea is very wise. What mounting bolts will you be using on the block?
Reply #156May 23, 2010, 09:24:28 am
« Reply #156 on: May 23, 2010, 09:24:28 am »
FYI, you might have axle to oil-drain interference.  Mine looked very similar to that at first, and they did interfere.
Reply #157May 23, 2010, 09:49:58 am
GEE-BEE
  • 1604
« Reply #157 on: May 23, 2010, 09:49:58 am »
Thanx it is AMS3195 E Silicone foam with a acrylic sticky backing
Cheer's
GB
P.S. The waves are great here !  ( South Pacific )
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #158May 23, 2010, 10:34:40 am
« Reply #158 on: May 23, 2010, 10:34:40 am »
I like it.
So far I have cut some bolts off and made studs that go into the back of the block. There are 3  M8-1.25 threaded bosses around where the 1.6D is on the back. I was going to try and triangle a brace from them. I think I will then weld a piece to the DP with a slot in it so it can be easily bolted together. I am open to any suggestions though.
Thanks for the heads up. I wouldn't have ever guessed that. The line is fairly flexible and I cut it long, so I may have some options. What did you do?
Anyone have the complete guide to swapping 90mm to 100mm cv?
A body man I am not. I am quite proud of what I have accomplished, but it isn't quite show quality. The closer it comes to painting it, the more I think I may wait.
Reply #159May 23, 2010, 01:02:28 pm
NintendoKD
  • 931
    • myspace page
« Reply #159 on: May 23, 2010, 01:02:28 pm »
Cheer's
GB
Try stopping by Okinawa, it's nice there and pretty cheap, and the folks are real nice.  Enjoy the vacation.
Reply #160May 25, 2010, 09:51:45 am
« Reply #160 on: May 25, 2010, 09:51:45 am »
I got a -10 AN 90* pushlok fitting from Jegs, the fitting I welded on the pan is pretty shallow, so the fitting basically points straight up.
Since I didn't have any choice before, I "threaded" the axle between the drain line and block and ran it that way for a while.  It did rub some, when I removed it, some of the stainless line was worn away.  I fixed it by replacing it with a 90* fitting when I had to replace the passenger side axle but then ended up cross-threading the -AN fitting when attaching it to the pan.  It leaked some, but I ran it that way for a while once again.
I just now fixed it a final time and used a pushlok fitting instead with a clamp, that way if I have to pull the turbo it will be a lot easier than messing with a traditional -AN type fitting.
...Of course, I also installed a catch-can, and there was too much restriction and it popped the dipstick tube out blowing 2 quarts of oil during my commute home....
Someday this thing will be leak-free.   :'(
Reply #161May 25, 2010, 03:06:59 pm
« Reply #161 on: May 25, 2010, 03:06:59 pm »
Thanks for the tip. I might try to sit it down in the engine bay tonight and see what it looks like. The line is flexible enough I maybe able to zip tie it to the mount out of the way. My fitting in the pan is welded and not able to be changed. I asked about making a stainless like my feed line and my cost with the fittings will still be about 30 bucks. So this one will wear in...hopefully before it wears out.
still up for ideas on the DP brace if any have some :D
Reply #162May 25, 2010, 04:22:03 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #162 on: May 25, 2010, 04:22:03 pm »
I really really like your DP brace. I need to make one.
Also, i used (haha) craft foam sheets from walmart and used elmer glue to hold it to my heaterbox doors.
my one word of advice is to make sure the doors are overlapping. you dont want to cut the sheets to the size of the metal doors. you want it to over lap a bit and get a perfect seal.
The difference is incredible.
as for ideas on the brace. I think your have it right in that picture there. use the two bolt holes (Edit: sorry there are three) in the block to make a brace. make it out of 1/4' angle iron.
tools needed: welder of any kind, file, something to cut the angle iron with - a chop saw works great but a hacksaw will do the trick, and a drill to drill bolt holes!!! Or if you're really good you could get some flat bar and stack them, then drill & tap.
« Last Edit: May 25, 2010, 04:25:01 pm by Smokey Eddy »
Ed
Reply #163June 01, 2010, 07:01:47 pm
« Reply #163 on: June 01, 2010, 07:01:47 pm »
Fender is welded inside and out. I didn't worry too much about the inside as I will bury it all in undercoat. I also started the patch in the back of the fender I didn't know was there until I was going around the car hitting stuff to make sure it was all solid. I have to weld a hole in the pass rear rocker, the holes for the plastic pieces on the driver rear, and my downpipe brace. After that I believe the rust bucket will just be a bucket and in no more need of welding. I have used about one and a half 11lbs spools(15-16lbs for the mathmatically challenged) of .023" wire so far.
I had to cut the oil drian out of the pan. There is NO WAY a 45 degree fitting will work with the hole I have drilled. I need to get another fitting and weld that.
I need to get the trans back from brokevw.
I need to decide if I am painting it now and if so should I stay stock or go black. I love the black:D
I believe it is just a bunch of parts that need assembled for the most part and hopefully end of June it will smoke to life. I will post the pics of the fender if anyone is interested. I need to take some first.
« Last Edit: June 02, 2010, 04:17:16 am by theman53 »
Reply #164June 02, 2010, 07:23:56 am
« Reply #164 on: June 02, 2010, 07:23:56 am »
Sounds like it's coming along!
If you've already paid Brian for the tranny work, I could swing by and grab it from him tomorrow on my way home from work, I'm off on Friday so if you're in the Mt. Vernon area I can hand it off to you.  Might cut your trip in half or so.  Otherwise, I'll probably see him this weekend at Cincy and I could grab it then.
Let me know if I can help you out.  There are advantages to working in Columbus.  :D
