Author Topic: Starting a turbo build...Videos of it running :D  (Read 140932 times)
Reply #105March 13, 2010, 05:48:51 am
Re: Starting a turbo build and...
« Reply #105 on: March 13, 2010, 05:48:51 am »
yeah look back on page 5...the hole was biggend and welded. Yeah it was bad. I was going to go out this morning to the farm and work, but it is the little ones 5th birthday party and the wife frowned on it
Reply #106March 13, 2010, 06:00:02 am
macka
  • 957
« Reply #106 on: March 13, 2010, 06:00:02 am »
jeez, thats a gap. Wives always frown, its in their job description
Quote from: Vincent Walden
I do know that I drive torque,  while listening to my friends prattle on about horsepower.
Reply #107March 13, 2010, 06:25:36 am
« Reply #107 on: March 13, 2010, 06:25:36 am »
Yeah I understand her point and I want to be here too. I could have done both though. I might work on something yet today. I still need to find an argon bottle-cheaper that is.
Reply #108April 08, 2010, 08:43:55 pm
« Reply #108 on: April 08, 2010, 08:43:55 pm »
Driver side welded.
I need to weld in a fender portion on the pass. rear and a hole in the pass. floor pan and I believe the welding will be done. I would also like to weld the holes shut on the part of the rear fenders that hold that plastic peice. Then use filler to level it out.
Then I think I am going to figure out what to do with the paint on it. I would like just to take it back close to the factory finish. 20 plus years of road and it has chips all over it...not to mention a giant hole in the passenger rear fender I am going to weld up.
I took the crank out of the engine last night and to the machinists today. Having it cut for the D sprocket so if I get enough cash to setup a serp system or have a big audio setup I won't have any crank issues.
Should pull the old engine and trans this weekend if the tractor is there. I would like to split them and see about a bolt kit and possibly a locker. Which leads me to my next question, what is available for a limited slip diff? Someone was talking about a 40% kit??? I just want to price it and see. If it is too much I will probably just buy a used 020 or 02A later when I can afford it. If it is reasonable I would love to attempt it or see if my buddy Troy can help me with it. Any ideas or places to look for trans LSD/40% kit would be awesome. I think brokevw has a walkthrough on how, I just need to know what.
Reply #109April 08, 2010, 09:02:15 pm
« Reply #109 on: April 08, 2010, 09:02:15 pm »
http://www.evwparts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=TT498082&Category_Code=TTLimitedSlipDiff
i tried to find it on the peloquin website.. but i could not for the life of me... i found an %80 kit tho..
Reply #110April 08, 2010, 09:04:37 pm
« Reply #110 on: April 08, 2010, 09:04:37 pm »
Reply #111April 08, 2010, 09:06:55 pm
« Reply #111 on: April 08, 2010, 09:06:55 pm »
 :o :o :o
That is a little more than I want to spend. Good find though.
I don't get it I can buy a locker for a 9" ford, Dana 44, 60, or the corperate series for 1/2 of that or less...must be the import nature.
edit just saw the 40% kit...I like it. Now to find the bolt kit and figure out how to make it work :D
Reply #112April 08, 2010, 09:08:05 pm
Reply #113April 09, 2010, 03:34:32 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #113 on: April 09, 2010, 03:34:32 am »
Driver side welded.
question: where can I get more info on this D-SPROCKET thing, I am pretty sure that it is for me, being that my build will go into a completely different ca, and run multiple accessories.
thanks,
Kevin
you know, decarbonated beer is a better coolant than the stuff you buy at the auto store, and is better for you...... really
"If the boost were to rise then the throttle would remain in the wide-open throttle position, which might be fun, but probably not for long"Libbypapa
Reply #114April 09, 2010, 07:57:14 am
« Reply #114 on: April 09, 2010, 07:57:14 am »
i believe it is merely machining your crank nose for a TDI sprocket, nothin fancy.
Reply #115April 09, 2010, 10:38:06 am
« Reply #115 on: April 09, 2010, 10:38:06 am »
its not some magical crank improvement, just take and cut a TDI style nose on the crank and run the TDI sprocket. you honestly probably wont even need it unless you are going to be running power steering, ac, an alt, and other things.
Reply #116April 09, 2010, 02:33:33 pm
« Reply #116 on: April 09, 2010, 02:33:33 pm »
To me it is chicken soup for a cold. It isn't needed, but can't hurt anything. I am going to eventually setup A/C and higher output alt on a serp setup. I just don't want to chance it on this build after 3 years. The other maybe fine, but I am going the safe route as I don't have it in the car.
BTW..."as I don't have it in the car" meaning engine, that phrase has cost me about 1,000 dollars. There have been 20 things I have done in the up to 100 dollar range that have added up. Just because the engine wasn't in the car yet and I might as well do it now kind of thing. I hope to get it done soon though.
« Last Edit: April 09, 2010, 04:17:09 pm by theman53 »
Reply #117April 09, 2010, 04:36:34 pm
« Reply #117 on: April 09, 2010, 04:36:34 pm »
PELOQUIN 020 80% KIT  Name: PELOQUIN 020 80% KIT
Part Number: 020498080az
Price: $95.99
Description: FITS 83 & UP 020 WITH 100MM CV more info (application guide)
Quantity in Stock: 2
Ground Shipping: $FREE GROUND IN THE LOWER 48 STATES
So how do I know if the 86 jetta I got has 100mm cv's???
Also, this is the best price I found for a bolt kit 53.99...http://www.jegs.com/webapp/wcs/stores/servlet/KeywordSearchCmd?itemPerPage=30&langId=-1&Ntk=all&catalogId=10002&Ne=2&Ntt=gears&storeId=10001&Ntx=mode%2Bmatchall&N=4294965419
anybody have a better spot?
Reply #118April 09, 2010, 04:41:51 pm
« Reply #118 on: April 09, 2010, 04:41:51 pm »
http://scirocco.org/
click on gears at the bottom of the page. the small lower table has all the trannies broken down by flange size. just locate your tranny code on it. im thinkin you have 90mm hubs tho. but i dont see why there would be a difference. they are completely interchangeable, and do the same damn thing.
Reply #119April 09, 2010, 09:25:28 pm
NintendoKD
  • 931
    • myspace page
« Reply #119 on: April 09, 2010, 09:25:28 pm »
I am using the franken engine in the Toyota MR2 Spyder, 250-300 BHP in a 2400 lb vehicle could be fun ;D :o I will need the d-sprocket for all of the acc. to bolt up.  this thread is going to be useful, because I also need to find a tranny and need to work out some details using cv's etc.  No jack intended, just sourcing out some much needed info, and sorting some problems.
thanks,
Kevin
