Author Topic: The Hybrid Turbo is complete  (Read 6155 times)
April 06, 2007, 10:11:41 pm
Darkness_is_spreading
  • 288
« on: April 06, 2007, 10:11:41 pm »
My GF was seeing her cousins new baby so I decied to build up my Hybrid Turbo with K24 exhaust side and    K26 cold side........
I will post pics later but    the most important part is  to make sure you take everything apart  up to the ringlet ( the two open ringed shims that are 120 or in my case 180 degrees out of alignment)
Replace the K24 one for a K26  one and every thing else that is above the ringlet must be changed to K26(ie housing).  I also found that when bolted back together, that I did not need a shim under the K26 impeller because I was using the K26 housing.
but I broke the rubber gasket  :x so I will be in need of a rebuild kit,   SO I will break the turbo down and post pics of everything.
92 Jetta 1.6 T (Sleepin)
Reply #1April 06, 2007, 11:13:30 pm
Black Smokin' Diesel
  • 656
« Reply #1 on: April 06, 2007, 11:13:30 pm »
If you're using the k26 impeller does this mean you still have the k24 impeller lying somewhere? If it's in perfect shape and you're willing to sell it, PM me. If you have a working k24 wastegate that would be awesome too :wink:
Reply #2April 21, 2007, 05:55:13 am
Kudagra
  • 738
    • www.no-coast.com
« Reply #2 on: April 21, 2007, 05:55:13 am »
Thats the nice thing about the KKK turbos...they bolt right together.
I also need to get the rubber seals. The rebuild kit I got from here didnt have the rubber o-ring or the wastegate gasket. Other then that it was a super nice kit.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #3April 21, 2007, 06:55:58 am
Mk2Fanatic
  • 93
« Reply #3 on: April 21, 2007, 06:55:58 am »
any pics yet I'm looking to do the same...
5 VW's: Mojave beige (LE1N) Mk1 rabbit 16V; Mk2 Jetta wolfsburg TDI conversion;Mk2 1.6TD Twin Charged Project; 86Mk2 1.6TD Jetta (daily); 1988 1.6NA Jetta; 1994 Passat 1.9TD donor
Reply #4February 17, 2008, 03:06:11 pm
subsonic
  • 1836
« Reply #4 on: February 17, 2008, 03:06:11 pm »
How is it working?
Reply #5June 16, 2008, 08:25:11 am
  • 288
« Reply #5 on: June 16, 2008, 08:25:11 am »
This build is very similar to the K24 break down and rebuild, but the integration of the K26 Compressor housing, bearing, compressor and the housing need to be swapped.
I tested my wastegate and was playing around with the waste gate adjustment screw, and found the max or locked setting and least or minimum boost setting. Makes a nice click noise, and I had to blow alot of diesel soot build up out of it.
I'm gonna post pics tomorrow, before it goes to be balanced.
I wish I could have bought a Dieslicious turbo rebuild kit but this kit I purchased will have to do, they play has dropped to almost zero after I checked the new non ball bearing bearings or sleave bearings I believe there called.
If anyone has a kit I would be happy to by it off of them, because I'm going to build another Hybrid Turbo for my 1.6 TD.
Reply #6June 16, 2008, 08:56:21 am
subsonic
  • 1836
« Reply #6 on: June 16, 2008, 08:56:21 am »
So this is the KKK versian of the T3/T4.  You now have a K24/6.  Where are you sending it for balancing?  What is the trim of your compressor wheel, and what is the A/R of the housing?  How big is the exit from the compressor?
Reply #7June 17, 2008, 10:07:46 am
  • 288
« Reply #7 on: June 17, 2008, 10:07:46 am »
I will measure these items tomorrow, but the Turbo is going to go in today for balancing and to have the shaft straightened. I purchased a K26/27 rebuild kit online and the turbo feels like it is brand new.
I will post pics later.....
Reply #8June 17, 2008, 02:12:29 pm
blkboostedtruck
  • 1535
Re: ....
« Reply #8 on: June 17, 2008, 02:12:29 pm »
Quote from: "Darkness_is_spreading"
yea i sure would like to see pics. and know how it works out? i got 5 K26's in the basement if anyone is interested?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #9July 02, 2008, 10:17:17 am
spencebm
  • 686
« Reply #9 on: July 02, 2008, 10:17:17 am »
how many dollars duane?
Ben Spencer
Reply #10July 02, 2008, 10:22:12 am
Re: ....
« Reply #10 on: July 02, 2008, 10:22:12 am »
Quote from: "blkboostedtruck"
Duane
4 man not 5!!
Reply #11July 02, 2008, 11:21:29 am
saurkraut
  • 904
Re: ....
« Reply #11 on: July 02, 2008, 11:21:29 am »
Duane
How much do you want for a K26?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #12July 02, 2008, 02:02:14 pm
blkboostedtruck
  • 1535
Re: ....
« Reply #12 on: July 02, 2008, 02:02:14 pm »
Quote from: "zukgod1"
Duane
4 man not 5!!
your right Dan! you do have dibs on one!
sorry guys i've neglected to keep an eye on this thread
i've got 3 K26's left each need new bearings except for one that has a bent shaft! some are watercooled centers! those are 55bucks and the oiledcooled are 45bucks plus shipping if your looking to do a hybrid this is what you guys need!
saurkraut, specebm P.M me if you want one or E-mail pics?
thanks Duane
'66 variant 1500S
Reply #13July 02, 2008, 09:45:35 pm
spencebm
  • 686
« Reply #13 on: July 02, 2008, 09:45:35 pm »
so if i want an oil cooled one then it won't be ready to throw on and run?
Ben Spencer
Reply #14July 03, 2008, 06:27:21 am
saurkraut
  • 904
« Reply #14 on: July 03, 2008, 06:27:21 am »
Dibbs!  I'll take one!
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
