General Information
General
Drove a Giles injection pump on a N/A diesel ** hp numbers**
4
Topic: Drove a Giles injection pump on a N/A diesel ** hp numbers** (Read 46981 times)
May 18, 2004, 05:03:45 pm
Dr. Diesel
Authorized Vendor
May 18, 2004, 05:03:45 pm »
Like the title says, Giles did some voodoo on his n/a rabbit delivery car's injection pump. Holy cow-pucky batman!! It's no turbo, but it scoots!! I'm sure with a dual downpipe/good exhaust, ported head and a lightened flywheel, it'd be a great little ride! For anyone wanting to up their N/A diesel without the hassel of turbocharging, send him your pump. IT'S WORTH IT!!!
May 19, 2004, 06:23:45 am
VWRacer
May 19, 2004, 06:23:45 am »
Rev higher? Maybe quicker advance curve? Should be normal "hot rod" stuff...
Stan
C-Sports Racer
May 19, 2004, 02:17:36 pm
Blades
May 19, 2004, 02:17:36 pm »
Tell me
May 19, 2004, 02:27:06 pm
fspGTD
May 19, 2004, 02:27:06 pm »
Yeah, I want to hear about the back-shaved pintle mod too. Full disclosure!!!
Jake Russell
Dieselicious
Turbocharger Upgrade/Rebuild Kits
May 19, 2004, 07:52:15 pm
Dr. Diesel
Authorized Vendor
May 19, 2004, 07:52:15 pm »
Just like the turbo engine's pump, the n/a diesel's rev limiter starts tapering off fuel delivery around 2800 rpm. The engine tops out at 5500 simply because it isn't getting enough fuel to pull to 5550. So, at 5400 at full throttle, it's more like you've let off the accelerator by 80%.
Now, change that rev limiter, modify the advance mechanism and some other nifty things, and you've got one hot little N/A bunny!
I don't think it was running out of air at all. I couldn't see any smoke at all in the mirror, and it was skip-to-my-loo-my-darling faster than any N/A diesel I've had before, and I've monkied with more than one of them, trust me.
May 19, 2004, 09:28:54 pm
VWRacer
May 19, 2004, 09:28:54 pm »
Actually, your answer makes sense to me, Doc. If you haven't actually added any fuel, then there is no reason it should smoke now if it wasn't before. "All" you have done is allow it to provide full fueling and advance to higher revs...cool!
I'll bet it
is
a zippy little bunny!
Stan
C-Sports Racer
May 19, 2004, 09:32:46 pm
QuickTD
May 19, 2004, 09:32:46 pm »
Me as well!
May 20, 2004, 12:22:24 am
leprechan
May 20, 2004, 12:22:24 am »
I might be interested in the future. You have a quote on what this might cost Dr. Diesel?
91' Jetta 1.6na, Monster Power!
May 20, 2004, 10:47:54 pm
Dr. Diesel
Authorized Vendor
May 20, 2004, 10:47:54 pm »
Call Giles
905-940-2266
May 26, 2004, 11:20:19 am
dieseltech
May 26, 2004, 11:20:19 am »
aprox. how much does giles cost to do up a pump for a td 1.6.?
i normally do my own pumps but it would be nice to see how one done up by "the man" performs
86 td jetta power everything dd (update off the road for major resto). 97tdi bare bones, DD
and a private junkyard of various other vw/audi/bmw/peugeot/volvo/toyota diesels!!!
Cummins has the worlds record for being the most efficient engine ever!!!!!
for converting fuel into noise!
May 26, 2004, 11:22:48 am
dieseltech
May 26, 2004, 11:22:48 am »
BTW where is he located too, thanks
Reply #11
May 26, 2004, 11:36:53 am
Spike_TDI
Reply #11 on:
May 26, 2004, 11:36:53 am »
I also want to know about the timing advance piston mod.
Reply #12
May 26, 2004, 12:04:11 pm
Dr. Diesel
Authorized Vendor
giles
Reply #12 on:
May 26, 2004, 12:04:11 pm »
Call Giles at the number above, or pm him. He's on this board. Look on the member list. I don't imagine he'd be giving away blueprints on how to build up such a pump, but you can ask about pricing for sure.
Reply #13
May 26, 2004, 12:45:33 pm
dieseltech
Reply #13 on:
May 26, 2004, 12:45:33 pm »
i dont want blueprint or anything like that. just wanted to see and feel the magic he works on the pumps, compare to some of the ones i have done up. i dont have a clean or prcise enough machine shop to preform most of the things he would do! i just adjust internal and external screws/springs. thanks
Reply #14
June 05, 2004, 05:32:30 am
Dr. Diesel
Authorized Vendor
WOW!
Reply #14 on:
June 05, 2004, 05:32:30 am »
Ok, so you remember me saying that I drove a Giles-tweaked N/A rabbit, and that I said it really scooted, and probably thought "yah, whatever"
WELL.......
We Gtech'd it. The little bunny picked up 22 HP AT THE WHEELS!!!
This test day was 2 degrees hotter than the day when it was tested before the mods.
So picture a n/a diesel, ported/polished, nice intake, header and exhaust, close ratio lightened flywheel. That'd put it up near stock GTI specs, probably with more torque!
COOL!
4
General Information
General
