Author Topic: New Here from Victoria BC  (Read 4942 times)
May 30, 2006, 10:20:47 am
Chestrockwell
  • 95
« on: May 30, 2006, 10:20:47 am »
Hi. Just found this great forum. I've got a 97 jetta td. So far I've turned up the charge pressure and fuel and put in a 1.6 boost pin. Also have had a polished ss lake pipe on for a while. It's only 2" but it's totally open from the turbo and seems to make a difference to a stock engine. Since waking up the engine I want to put on a bigger side pipe but it'll still be polished ss. It's all grimy now but nice and shiny after a little scrubbing. Anyways, this is a great forum.
some pictures
and if this works, a video from yesterday on the hiway; full pedal at about 1200 in 5th, 16psi @ 2000, shut down at 140k, 1100F, 21psi 3800rpm. Ya, 21psi stock kkk turbo and engine; I'm a greedy bastard. It'll blow up soon I'm sure.
Reply #1May 30, 2006, 09:54:44 pm
LeeG
  • 401
« Reply #1 on: May 30, 2006, 09:54:44 pm »
hey, welcome!
I like the side pipe idea, dont see that much these days.
'97 Passat TDI
Reply #2June 05, 2006, 12:07:14 pm
snootworks
  • 7
« Reply #2 on: June 05, 2006, 12:07:14 pm »
Greetings!
Reply #3June 05, 2006, 02:35:03 pm
MacGyver
  • 245
« Reply #3 on: June 05, 2006, 02:35:03 pm »
Looks to be sitting higher than stock...? 8)
Reply #4June 05, 2006, 04:47:49 pm
Chestrockwell
  • 95
« Reply #4 on: June 05, 2006, 04:47:49 pm »
I don't know, it's sitting on a slight slope in that picture... rides fine, stock suspension afaik.
Reply #5August 13, 2006, 07:42:24 am
Chestrockwell
  • 95
Same car better power!!
« Reply #5 on: August 13, 2006, 07:42:24 am »
Well, finally got all the mods done I've been planning;
T3 turbo (rebuilt)
Added an intercooler
2.5 full ss open exhaust
2.25 full aluminum ic piping
head and main stud kits
rebuilt injectors and holy grail Superior Injection Pump!
Giles, you're a madman!
This thing goes good, just gotta fix the new found clutch slippage.
The turbo I bought off a guy through ebay had a broken wastegate valve stem and no cannister so I had to fab up a crazy linkage and use my old k03 wastegate. Turns out that because of my slipping clutch and small g60 intercooler I have to run it closed wastegate anyways. owell, the car is a blast to drive. Runs 25 psi max. Seems a little low on a 1.9 closed wg but what the hell, it doesn't spike over that ever.
Anyways here's a few pictures
Anyways, back to no-internet land for a few days.
Peace[/img]
Reply #6August 13, 2006, 10:31:40 am
Dr. Diesel
  • 1341
« Reply #6 on: August 13, 2006, 10:31:40 am »
weclome!
Hey, what are all those tall green things beside the highway?!
 :lol:  :roll:
BC OR BUST!!
