Author Topic: all i can say is,WOW  (Read 11056 times)
April 22, 2006, 04:15:47 pm
hillfolk'r
  • 1532
« on: April 22, 2006, 04:15:47 pm »
:P  :P check it check it!!!!
but  this part sucked!!!
i took a chunk of hose and 2 clamps,,and an old bolt,plugged the oil feed line,drove it home 55 miles!!!
where is it?? i dunno,,no one came up to me with it,,maybe some is still in ehhaust??,idid not hear any,,im tired,,spelling sux!!!!
i told you guys i need a bigger turbo!!!!!!!
Throttle cables ftw
Reply #1April 22, 2006, 05:58:14 pm
hillfolk'r
  • 1532
« Reply #1 on: April 22, 2006, 05:58:14 pm »
15 views.and no posts???
Throttle cables ftw
Reply #2April 22, 2006, 06:02:26 pm
andy2
« Reply #2 on: April 22, 2006, 06:02:26 pm »
awesome,thats nuts.
Reply #3April 22, 2006, 06:29:06 pm
hillfolk'r
  • 1532
« Reply #3 on: April 22, 2006, 06:29:06 pm »
this turbo owes me nothing,,i ran it on my truck,for about 2 years,, and then about 1.5 years on my 1.6 td  also ,,,a lot of the time i  ran the boost controller closed/full boost. im just glad it wasnt the intake side! :shock:
Throttle cables ftw
Reply #4April 22, 2006, 06:32:39 pm
andy2
« Reply #4 on: April 22, 2006, 06:32:39 pm »
How much boost were you making at the time.I guess if you know the weight of your car you could figure out what kind of hp it was making.
Reply #5April 22, 2006, 07:05:07 pm
hillfolk'r
  • 1532
« Reply #5 on: April 22, 2006, 07:05:07 pm »
oh i dont push normal boost,,,i was pushing "S" pounds,, :shock: ,thats my vdo 30psi boost guage ,going halfway between 30 and the  zero pointer. my guage says "psi" in that spot so, s pounds  of boost,,about 35 i figure,,,,, :wink:
,,see the set of 3 guages onthe right?? the one in the middle of them is boost, i dunno if its visible or not,,the other day i rode shotgun while a buddy drove,,i saw it go to the zero pointer a few times in 5th gear,,,
Throttle cables ftw
Reply #6April 22, 2006, 07:30:43 pm
935racer
« Reply #6 on: April 22, 2006, 07:30:43 pm »
Thats cool man, I know exactly what that one sounds like, racin around than boom lots of smoke and this little rattle of turbine wheel pieces going through the dp and out the exhaust :twisted:  I've blown up about 3 or 4 of those, well between me and my buddies in our diesels anyways.
Good time too man keep it up, hope to get some times in my caddy mech tdi this summer too
Reply #7April 22, 2006, 09:27:44 pm
macsdub
  • 165
« Reply #7 on: April 22, 2006, 09:27:44 pm »
Nice going, Blake.   :D
most of the time this is hilfolk'r... ive forgotten my password
Reply #8April 22, 2006, 11:28:19 pm
hillfolk'r
  • 1532
« Reply #8 on: April 22, 2006, 11:28:19 pm »
heehee i found little chunks inthe downpipe flex. ill take a few more pics of the downpipe tomorrow,,theres lots of dents from the inside .i cant find my 12 mm 12 point socket,,aargh,,only thing holding me up from turbo removal.,i got the 2 outers loose,,ill get it swapped tomorrow,i think,,,,,got my kkk from my 84 1.6td,,wonder how long this one will last,,,,
Throttle cables ftw
Reply #9April 23, 2006, 01:40:31 pm
TDForNow
  • 131
« Reply #9 on: April 23, 2006, 01:40:31 pm »
That'll WAKE you up!! Looks like it WAS a T-3 What was it?
'85 Quantum 1.6TD
'04 Passat 2.0 8vTDI
Reply #10April 23, 2006, 03:14:25 pm
« Reply #10 on: April 23, 2006, 03:14:25 pm »
Nice times and good carnage points there!
You are lucky the little bugger didnt slash a heater hose as he made his escape!
Reply #11April 23, 2006, 03:59:14 pm
hillfolk'r
  • 1532
« Reply #11 on: April 23, 2006, 03:59:14 pm »
Quote from: TDForNow
yea,spooky,,was a t3 from an 86 jetta td,,a lot of bad things coulda happened,,,heater hose,thru firewall,in my leg :roll: maybe hit the brake bottle and snap it off,,it would stop,,once:)i almost threw up as i was shutting it down at speed,thinkin 4500$ were down the toilet :oops: is it the exhaust side that usually goes?? nothing happened on the compressor side,,thank god!!!,,i got it all swapped over to a kkk now,,worst thing is im all itchy from the wrap, iran it for a minute to check for leaks etc,checked ok. its gonna smell bad once it warms up! you gotta be careful,sometimes  the wrap will catch fire if oil soaked,take it to car wash and clean 'er out later :roll:
Throttle cables ftw
Reply #12April 23, 2006, 04:27:21 pm
TDForNow
  • 131
« Reply #12 on: April 23, 2006, 04:27:21 pm »
Yeah..... folks ain't gonna like to be behind you when you cook the oil outta the pipes!!
 Blew a turbine in a Mack a few years ago, shop replaced the turbo, but didn't "drain the oil" from the exhaust. LOL....... killed a 100 yd wide swath of bugs for the first 20 miles!
'85 Quantum 1.6TD
Reply #13April 23, 2006, 05:47:12 pm
hillfolk'r
  • 1532
« Reply #13 on: April 23, 2006, 05:47:12 pm »
we never clean them out,heck i work with jokers,they would pour in some more to be sure!!,,we drive them to burn them out,heehee,its fun,yea the thing is loaded inside the exhaust,,it was funnydriving itlike that,,musta caused a vacuum above 3000 rpms,and drew oil up thru the drain,,,cause i had the feed plugged toget home,,ihad to do about 55 or so all the way back,,any more,it would fog big time!!!,,,,,actually,imgonna go "burn 'er out " right now,except it sucks its raining,no traction :cry:
Throttle cables ftw
Reply #14April 24, 2006, 11:46:46 am
2383 GTD
« Reply #14 on: April 24, 2006, 11:46:46 am »
Very nice times...  get some better traction, and your 60ft time will drop you into a 13 second run  8)
I might have a turbo for you...
