General Information
General
Quick bearing question
Topic: Quick bearing question (Read 6067 times)
February 13, 2008, 11:58:41 am
February 13, 2008, 11:58:41 am »
I'm putting my main bearings in, and have discovered I have one set with oil holes on both instead of one with an oil hole & groove, one flat. Anyone see any problems with running it like that, or should I put one of my old ones in?
February 13, 2008, 02:31:55 pm
FineFrank
Bearings
February 13, 2008, 02:31:55 pm »
The flat one goes in the main cap. No need to use an old one. It won't give you the slightest trouble as long as you don't plug off an oil hole, and the cap doesn't have one.
Frank Longtine
1983 Rabbit Diesel 4 dr/ 1.6NA
1997 Rokon Trailbreaker
1984 Ford F-150/ 300-6
"The welfare of humanity is always the alibi of tyrants" -Albert Camus-
February 13, 2008, 06:59:38 pm
TedV
February 13, 2008, 06:59:38 pm »
the 4th main gets the 2 halves with the hole and groove. I thought there was a post about the cap bearings on here someplace, but my searching isn't lucky tonight. The bearing set I got said what went where, but I'm not close to the garage tonight.
edit: it's the groove all the way around that is important,
February 13, 2008, 07:10:01 pm
February 13, 2008, 07:10:01 pm »
Well, damn, I lucked out then as I put it on #4. My bearings, Glyco, said nothing.
February 14, 2008, 05:53:10 am
subsonic
February 14, 2008, 05:53:10 am »
I think it is in the faq section under engine rebuilding.
1985 VW Golf 5-spd, 4-door, 1.6NA Bought from orig. owner in Savannah with 42,000 miles.
1980 VW Rabbit LS 5-spd, 4-door 1.6NA almost 450,000miles RIP
February 14, 2008, 06:06:40 am
February 14, 2008, 06:06:40 am »
Crap, so #4 has 2 holes? I didn't remember seeing any in my set, so I may have that one somewhere else. Guess I know what I'm doing today... :evil: :evil: Though much better to find out now than later.
General Information
General
