Author Topic: Higher idle  (Read 2170 times)
August 05, 2007, 01:47:28 am
Benjamin
  • 485
Higher idle
« on: August 05, 2007, 01:47:28 am »
How can you increase idle to 1500 or 2000, but it may not hang in rpm, so it need to come back to idle after you reved.
Greetz, Benjamin
Must make +250hp
Reply #1August 10, 2007, 11:33:57 am
Zulfiqar
  • 254
Higher idle
« Reply #1 on: August 10, 2007, 11:33:57 am »
I dont think that the idling governor would allow a 1500 rpm, it only works till 1000 rpm IIRC
Diesel IS the future
Reply #2August 10, 2007, 12:41:31 pm
QuickTD
  • 1156
Higher idle
« Reply #2 on: August 10, 2007, 12:41:31 pm »
The idling spring would have to be changed to a slightly stiffer one.
 The stock idling spring would be completely compressed at 2000rpm, or on later pumps with a seperate idle lever, would have insufficient tension to reach 2000rpm.
