Higher idle
Topic: Higher idle (Read 2175 times)
August 05, 2007, 01:47:28 am
Benjamin
Higher idle
August 05, 2007, 01:47:28 am »
How can you increase idle to 1500 or 2000, but it may not hang in rpm, so it need to come back to idle after you reved.
Greetz, Benjamin
SMOG alert, engine running again!
Must make +250hp
August 10, 2007, 11:33:57 am
Zulfiqar
Higher idle
August 10, 2007, 11:33:57 am »
I dont think that the idling governor would allow a 1500 rpm, it only works till 1000 rpm IIRC
Diesel IS the future
August 10, 2007, 12:41:31 pm
QuickTD
Higher idle
August 10, 2007, 12:41:31 pm »
The idling spring would have to be changed to a slightly stiffer one.
The stock idling spring would be completely compressed at 2000rpm, or on later pumps with a seperate idle lever, would have insufficient tension to reach 2000rpm.
Higher idle
