Author Topic: Fresh idea for injector modifications. Seeking input.  (Read 3634 times)
August 01, 2007, 11:49:16 am
subsonic
  • 1836
« on: August 01, 2007, 11:49:16 am »
I saw this while I was checking out some info on extrude honing.
This guy is running a mech inj pump.  Massive flow increase through his injectors.  I am thinking you would greatly reduce pumping loss.  Lots and lots of possibilities.
http://www.extrudehone.com/news/details.php?id=9
Reply #1August 01, 2007, 08:36:12 pm
IRoll
  • 25
« Reply #1 on: August 01, 2007, 08:36:12 pm »
Wow, I'm intrigued.
I really may do this, it's pretty cheep.
http://gethoned.com/parts.php?get_price=yourparts&show=diesel
Thanks for the link.
-E
How fast?
As fast as it takes.
Reply #2August 01, 2007, 09:31:49 pm
subsonic
  • 1836
« Reply #2 on: August 01, 2007, 09:31:49 pm »
There local for you buddy. :)
They have a section for group buys.  Good discount if you get enough parts.
So for the injectors, would you send them the nozzle or the whole body?
I sent them a e-mail asking if they have done any work on the 1.6, 1.9 idi and TDI injectors.  I told them that if they had not, I could probably find some volunteers who would offer up some injectors for modification.   Test bed anyone? :wink:
I also asked about what they could do with our heads.  I was told that they have done them before, and that you could expect a
15-20% increase when done.
The whole thing is kind of interesting.  I did quite a bit of reading on the company.  They seem to be the real deal.  Good gains to be had in many different applications.
 I was wondering about our exhuast manifold.  A equal length manifold kicks ass, but is not cheap.  Our stock manifold appears to suck hind tit as far as performance flow.  I have not been able to find any other option as far as exhaust manifolds go.  I was wondering how much you could remove from the stock manifold  for big flow / spool time improvement?
That train of thought leads me right into my other question.
Porting V.S Extrude Hone ?
From what I have been reading, the extrude hone talks about increasing volume and flow velocity.  The bigger gains of the two being velocity.
If I had my head ported, would it be the same?  Posts on other sites said that a serious port job will offer more flow than the extrude hone.
Velocity V.S Volume?      hmmmm....
I am wondering, if you had this done on your head-- intake and exhaust ports,  would it remove material at the same rate through out the whole channel?  Would this create thin spots in some area's that a regular port job would not?
Has anyone here  used this service before?  Whats you take on it?
Reply #3August 02, 2007, 04:32:39 am
foxracer1
  • 991
« Reply #3 on: August 02, 2007, 04:32:39 am »
I wonder if i had my merc NA34X injectors done about 30% if that would be to much fuel. Or not enough :twisted:
I haven't got my VNT on yet so i haven't had a chance to put the injectors in. I'm kinda waiting cause i think the n/a will be over fueled.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #4August 02, 2007, 05:16:54 pm
Dr. Diesel
  • 1341
« Reply #4 on: August 02, 2007, 05:16:54 pm »
I don't think it'll work on a pintle style injector. :(
Reply #5August 02, 2007, 11:55:57 pm
Audi80
« Reply #5 on: August 02, 2007, 11:55:57 pm »
Quote from: "Dr. Diesel"
x2
Why worry about injectors. Stock 1,6 ones will flow enough to get 250+whp. It is tested and dynoed... Injector head ache is for direct injection guys  :wink:
Reply #6August 03, 2007, 06:56:44 am
subsonic
  • 1836
« Reply #6 on: August 03, 2007, 06:56:44 am »
What about the extrude hone vs porting?
It appears that one opf the big flow restrictions is the stock exhaust manifold.  I have not seen a better replacement yet.  Could this open it up a bunch for better flow, or would porting be better?
Reply #7August 03, 2007, 05:11:07 pm
Dr. Diesel
  • 1341
« Reply #7 on: August 03, 2007, 05:11:07 pm »
i don't think the exhaust manifold is a significant restriction. think about the size of the prechamber hole that all the air and exhaust has to go in an out of a zillion times a minute. I had a 1.6L TD spin happily over 7000 rpm with a stock exhaust manifold.
Reply #8August 04, 2007, 07:59:59 am
subsonic
  • 1836
« Reply #8 on: August 04, 2007, 07:59:59 am »
7K! Wow.  So what is the benifit to going to a equal length exhaust manifold Like Passenger is selling?
Reply #9August 04, 2007, 01:02:06 pm
« Reply #9 on: August 04, 2007, 01:02:06 pm »
Quote from: "subsonic"
lower EGT's and less exhaust back pressure.  it also eliminates hot spots due to the fact that the outside two outside cyls have a longer run and the two inner cyls have a shorter run so they are more prone to heat damage.
i've seen a toyota diesel with 0 compression on one cyl going up to 320 on the other end.  if an equal length manifold was used, it probably could have survived whatever the p/o did to it (probably had it to the floor towing something huge, or going uphill)
