Author Topic: What are the odds that this head is junk?  (Read 8424 times)
July 30, 2007, 02:11:28 pm
« on: July 30, 2007, 02:11:28 pm »
I think my friend may have timed his engine wrong and bent a few valves. This is what we are looking at. He is in Toronto so I can't really have a look at it myself
What are the chances that the head will need to be replaced?
If you can't tell the cam lobe is not touching the lifter, it's stuck down there. He said he cranked the engine for about 40 seconds but it did not start after he timed it. If he turns the engine CCW the piston will push the lifter back up but it won't move on it's own
Reply #1July 30, 2007, 02:25:22 pm
bevboyy
  • 200
« Reply #1 on: July 30, 2007, 02:25:22 pm »
You gotta pull the head to confirm. That lifter may need to be replaced. Was the car running beforehand? Unless we can get a look at the head surface, I would say the head may be still good, but the bore for the lifter may need to be checked.  Have your friend remove the head, take the cam out and see if he can remove the bad lifter. The valves for sure will need to be replaced - also check the guides and seals.
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #2July 30, 2007, 02:34:29 pm
wikdslo
  • 103
« Reply #2 on: July 30, 2007, 02:34:29 pm »
Quote from: "bevboyy"
This is my car. Tyler is helping me out with it.
The car was running beforehand. I had changed the injector pump because the one on there was leaking. I thought to just put the timing back where it was after I swapped pumps... Sadly, I didn't know it was a destructive motor.. Nor did I think to turn it by hand first to find out if everything was groovey..
Live and learn i guess.
Will i need all the valves or just the 1?
Reply #3July 30, 2007, 02:50:45 pm
Black Smokin' Diesel
  • 656
« Reply #3 on: July 30, 2007, 02:50:45 pm »
Is it doing that with only this valve? I'd pull the cam and see if the valve springs aren't broken first.
Reply #4July 30, 2007, 02:53:16 pm
wikdslo
  • 103
« Reply #4 on: July 30, 2007, 02:53:16 pm »
Quote from: "Black Smokin' Diesel"
As far as i can tell, its only the one valve. The rest are all touch, and i CAN rotate this engine about 1/8 of a turn side to side, but then it makes that nice metal click and i know it wont go any further...
I'm going to take the head off and bring it up to a friends shop and have him check it out. I want this motor to last, and i've already spent a lot of time on the car, so I might as well do it right.
Btw, the motor has less than 50k original.. :(
DANG!
Reply #5July 30, 2007, 02:55:30 pm
bevboyy
  • 200
« Reply #5 on: July 30, 2007, 02:55:30 pm »
Just the one valve. Do us a favour and remove the head. Get us some pics of the suspect area. At this moment in time you may look into doing the timing belt and water pump, as your car is going nowhere at the moment....Even better, do the HG as well. Then you're set. :)
It's not that bad. It could have been running, then then the belt skips a couple teeth, and then you're into more $$$.
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #6July 30, 2007, 02:58:02 pm
bevboyy
  • 200
« Reply #6 on: July 30, 2007, 02:58:02 pm »
Only 50K? Then skip the waterpump. Upgrade to the 1.9 HG though..
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #7July 30, 2007, 05:19:30 pm
« Reply #7 on: July 30, 2007, 05:19:30 pm »
Before you commit get a pricey replacement Jonas I think I might have a head for you.
Reply #8July 31, 2007, 02:06:38 pm
wikdslo
  • 103
« Reply #8 on: July 31, 2007, 02:06:38 pm »
Ok, got the head off. Taking up to the shop now to have it checked and the valve(s) replaced.
Here are the pics. I wont be able to check the responses to this for a bit but dont make me cry too much k?
Reply #9July 31, 2007, 02:39:22 pm
  • 656
« Reply #9 on: July 31, 2007, 02:39:22 pm »
From what I can see, doesn't look like there was any piston to valve contact.
Reply #10July 31, 2007, 04:00:35 pm
« Reply #10 on: July 31, 2007, 04:00:35 pm »
sounds like the problem i had a while back with mine.. had it fixed.  one valve was almost 'dangling' there  :lol:  car drove alright and mileage was okay.  power was decent... just some weird noise at idle and part acceleration.
Reply #11July 31, 2007, 04:17:23 pm
bevboyy
  • 200
« Reply #11 on: July 31, 2007, 04:17:23 pm »
From what I see, all looks good. Get that one valve fixed and put on a 1.9 HG and new timing belt. You should be fine.
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #12July 31, 2007, 04:44:49 pm
wikdslo
  • 103
« Reply #12 on: July 31, 2007, 04:44:49 pm »
lol, you and your damn 1.9 HG.. If I knew what the heck it was.. i might be inclined to try it..
But at this point, I just need/want the car running asap.
Reply #13July 31, 2007, 04:49:38 pm
« Reply #13 on: July 31, 2007, 04:49:38 pm »
He has a solid lifter head, a metal HG is probably out of the question (yes I know it can be done)
Reply #14July 31, 2007, 05:03:51 pm
wikdslo
  • 103
« Reply #14 on: July 31, 2007, 05:03:51 pm »
Thanks for all the positive words guys. Here's hoping !
