Author Topic: where to get 1.6 rebuild kit?  (Read 3598 times)
July 21, 2007, 01:47:38 am
the4ork
  • 331
« on: July 21, 2007, 01:47:38 am »
i have a 1.6 n/a that im wanting to turbo charge... my machinist is adding in aba oil squirters...
now i need a complete rebuild kit for a mechanical lifter 1982 diesel engine... without the pistons...
need pretty much everything else... need guides, guide seals, headgasket, valve cover gasket, timng belt, all the gaskets to the block, main and rod bearings (cam bearings? intermediate shaft bearings?) ect. ect.
the entire engine was disassembled and hot tanked
(will TD pistons fit n/a rods?)
is there a diesel specific bently?
Reply #1July 21, 2007, 07:54:18 am
Justin
  • 455
« Reply #1 on: July 21, 2007, 07:54:18 am »
vwdieselparts.com
Jack has what you need and is great to deal with
good luck
Justin
www.archeryprostaffmi.com
Reply #2July 21, 2007, 09:47:07 am
« Reply #2 on: July 21, 2007, 09:47:07 am »
Mike_w on the site is also good to deal with.
Do you want a set of TD oil squirters instead of the ABA?
Reply #3July 21, 2007, 12:33:44 pm
Audi80
Re: where to get 1.6 rebuild kit?
« Reply #3 on: July 21, 2007, 12:33:44 pm »
Quote from: "the4ork"
Yes, they will fit.
Reply #4July 21, 2007, 05:06:55 pm
CoolAirVw
  • 175
« Reply #4 on: July 21, 2007, 05:06:55 pm »
Quote from: "burn_your_money"
What does ABA mean?
You got some TD squirters for sale?
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #5July 21, 2007, 07:12:42 pm
« Reply #5 on: July 21, 2007, 07:12:42 pm »
ABA is the engine code for the 2.0 gasser found in mk3s
Yeah I have a couple of sets for sale (TD squirters)
Reply #6July 21, 2007, 07:19:23 pm
subsonic
  • 1836
« Reply #6 on: July 21, 2007, 07:19:23 pm »
Quote from: "CoolAirVw"
What does ABA mean?
I do believe they where one of the super bands from the 80's.   :P
Reply #7July 21, 2007, 08:41:43 pm
the4ork
  • 331
« Reply #7 on: July 21, 2007, 08:41:43 pm »
i was only going to use the ABA squirters because i have a blown aba block from my 2.0T project... one of them was tweaked when i cracked a piston but i was able to bend it back into place...
i dunno if they squirt differently but im willing to givem a try, hell maybe they'll squirt more?
