Author Topic: Found a 82 diesel in a yard  (Read 4928 times)
June 23, 2007, 04:05:54 pm
firestorm13666
  • 204
« on: June 23, 2007, 04:05:54 pm »
I was geting parts for a friends car and we looked around the yard to see what all the had.I saw a few old rabbits and one was a diesel.It was 82 and the Vin starts with 1.The injection pump and injectors are long gone but the rest is there.So what would be some parts to get from it if i can?Thanks
Reply #1June 23, 2007, 07:49:09 pm
« Reply #1 on: June 23, 2007, 07:49:09 pm »
the only thing i almost always swipe from cars like that is the glow plug relay since they're 50 bucks a pop.
Reply #2June 23, 2007, 11:24:42 pm
firestorm13666
  • 204
« Reply #2 on: June 23, 2007, 11:24:42 pm »
The reason why i am asking is two fold.I have a 1986 MK2 Golf,and would like to get whatever useful parts i can.The other being i would love to have a MK1 with a diesel and knowing that if i do with a MK1 i can't be picket about diesel or not i would like to get the parts that make it a diesel so i could swap one in a MK1 if i do get it.Also how good are the fuel filter setup on the Mk1 compared to the MK2?Thanks
Reply #3June 24, 2007, 07:09:13 am
bevboyy
  • 200
« Reply #3 on: June 24, 2007, 07:09:13 am »
Take the head off it. if the cylinder walls look ok, and the engine turns over by hand, take the engine.
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #4June 24, 2007, 08:05:34 am
« Reply #4 on: June 24, 2007, 08:05:34 am »
Take the cluster
I think the fuel filter is just as good as the mk2 setup but I don't know for sure
Reply #5June 24, 2007, 09:46:03 am
« Reply #5 on: June 24, 2007, 09:46:03 am »
the mk1 setup is better, but only because the filters for it are like 10 dollars cheaper haha.
Reply #6June 24, 2007, 11:16:31 am
firestorm13666
  • 204
« Reply #6 on: June 24, 2007, 11:16:31 am »
So none of the wiring would be worth taking?Also it did have a non a/c braket :D .Anymore advice would be grate thanks.
Reply #7June 24, 2007, 12:14:48 pm
bevboyy
  • 200
« Reply #7 on: June 24, 2007, 12:14:48 pm »
depend on what you want to wire up. If you are planning to drop the diesel into a gasser shell, then as long at they are both ce1, ok, otherwise, just pull the relays...
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #8June 24, 2007, 11:06:13 pm
firestorm13666
  • 204
« Reply #8 on: June 24, 2007, 11:06:13 pm »
Sorry if i was not clear in my last post.I ment that i would like to have MK1 and know that finding a clean one is getting harder to find and if i do find one it might not be a diesel.This is why i asked about the wiring.Also what is CE1?Thanks
Reply #9July 09, 2007, 07:53:27 pm
ODwyerPW
  • 103
    • http://www.Espanglish.com.mx
« Reply #9 on: July 09, 2007, 07:53:27 pm »
If it has good plastic navy blue window cranks...take them.   they are tough to find.
If it has good navy blue trunk carpet..take it and sell it to me.
83 Rabbit LS Turbo Diesel
