Author Topic: pic of LDA pump and pic of eco pump?  (Read 3681 times)
June 19, 2007, 04:16:00 am
knowtwodrugs
  • 46
« on: June 19, 2007, 04:16:00 am »
I'm picking up a 1990 Jetta today and I'm not sure if the pump has the LDA or not.  Could I see some pics to get a better idea?  If it doesn't I'm pretty much screwed on upgrading the pump unless I get a different one right?
- Ayrer Performance & Machine -
Performance Valve Jobs, Rod Resizing, Crank Grinding & Polishing, Cam Bearings, Block Squaring, Block Boring, Head Milling, Etc...
 "Complete Engine Design For The Type Of Racing That You Do!"
609-835-0779
Over 25 Years Experience
Reply #1June 19, 2007, 07:14:06 am
yankeejim
  • 8
« Reply #1 on: June 19, 2007, 07:14:06 am »
If this is a stock US-spec '90 jetta, then it is non-turbo, and would have the non-LDA pump.
HOWEVER it may have the altitude compensation thingy that some later NA engines had, which looks similar to the TD LDA but does the opposite - it cuts  fuel in lean air, to reduce smoke (and your ability to accelerate)
This is a pic of a turbo diesel pump with the LDA, which in this pic is the shiny-ish round thing that sits on top of the pump:
'92 Jetta ECOdiesel
Reply #2June 19, 2007, 03:24:13 pm
knowtwodrugs
  • 46
« Reply #2 on: June 19, 2007, 03:24:13 pm »
I'm confused, there is definately a turbo on the car but there's no LDA.  How is it not turbo if there is a turbo?
609-835-0779
Reply #3June 19, 2007, 03:46:22 pm
foxracer1
  • 991
« Reply #3 on: June 19, 2007, 03:46:22 pm »
Eco diesels just don't have an LDA they obviously are still turboed.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #4June 19, 2007, 05:04:57 pm
« Reply #4 on: June 19, 2007, 05:04:57 pm »
ecodiesels technically are turbo diesels, they're just not as good as the "real" turbo diesels.... kind of like economical turbo diesel or regular turbo diesel.
Reply #5June 19, 2007, 06:19:49 pm
Black Smokin' Diesel
  • 656
« Reply #5 on: June 19, 2007, 06:19:49 pm »
Quote from: "Trev0rbr"
The ECO pump also has a 8mm plunger, which is the suck. The NA and TD pumps have a 9mm plunger.
Reply #6June 19, 2007, 07:03:23 pm
« Reply #6 on: June 19, 2007, 07:03:23 pm »
Eco diesels also have the K14, a nice small fast spooling turbo. Upgrade the pump (even to a NA pump) and you should have a quick car with minimal lag (relative)
Reply #7June 20, 2007, 03:50:11 am
knowtwodrugs
  • 46
« Reply #7 on: June 20, 2007, 03:50:11 am »
Yes I did notice that the turbo begins to spool almost immediately.  Are you serious that a NA pump will be an improvement?  That would be awesome, cos I have one laying around.  Of course, would a true turbo pump be an even better way to go even if I'll never be able to afford to send it to Giles?  =)
609-835-0779
Reply #8June 20, 2007, 02:29:52 pm
yankeejim
  • 8
« Reply #8 on: June 20, 2007, 02:29:52 pm »
Given that it has a turbo but no LDA, it's likely either a '91 ECO or it had an ECO motor swapped in at some point.  The configuration you describe was only offered in '91 and '92.
Send us a picture!
'92 Jetta ECOdiesel
Reply #9June 20, 2007, 02:53:20 pm
rallydiesel
  • 1880
« Reply #9 on: June 20, 2007, 02:53:20 pm »
Anybody use a K14 with a turbo injection pump and up the boost on the K14 to around 20 PSI? I think that would actually make for a pretty peppy ride.  :idea:
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
