Author Topic: Mk1 Golf/Rabbit external oil cooler how do they work?  (Read 3204 times)
June 06, 2007, 03:23:13 pm
Hillshy
  • 103
    • http://www.hillshy.co.uk
« on: June 06, 2007, 03:23:13 pm »
Hello all,
Finally got some time to drop out my 1.7na engine outa my vanagon, my td lump should be in over the next few days.
My td lump is an Sb Gtd engine from 1990 golf mk2, to that i have fitted a Rabbit/Golf MK1 1980 external oil cooler which i know there are others who have done the same thing, can anyone explain how they work? or can onyone provide details or exposed pictures of the internals?
Cheers guys :?
Hillshy T25 caravelle "Hilli" currently thrashing 1.6 td GTD engine
NOT SO FRIGGEN HILLSHY ANYMORE!
15psi of BOOST set my c'velle free
Reply #1June 08, 2007, 02:22:00 pm
Hillshy
  • 103
« Reply #1 on: June 08, 2007, 02:22:00 pm »
does anyone know ???
Reply #2June 08, 2007, 04:04:19 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #2 on: June 08, 2007, 04:04:19 pm »
Quote from: "Hillshy"
Well when I looked it up here...
http://www.vagcat.com/
It looks like a pretty simple air cooler. Oil flows through the hoses up to a oil thermostat then flows through the tubes in the cooler. The heat from the oil radiates into the fins in the cooler where it is taken away by air that flows past the fins.
Im not sure if thats what you want to know or not.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #3June 09, 2007, 01:25:29 am
Hillshy
  • 103
« Reply #3 on: June 09, 2007, 01:25:29 am »
Hi Kudagra,
cheers for the info/link, There's some sort of wax stat and spring thing going on inside and i believe once a certain temp is reached then the spring/wax stat may collapse/open and then oil flows into the external oil cooler, my Golf Haynes manual(our equivalent to bentley) shows a picture but doesn't explain how it works inside.
i will try to explain the internals. Oil flow inside the oil housing both flow and return all seem to merge into the central bore where a sprung loaded piston moves forward and back as oil temp changes. if the piston moves in one direction it keeps oil in the cooler housing, if the piston moves the opposite direction then, as it moves the outlet route to the external oil cooler is opened and therefore flows externally to the cooler. :?
its something like that, not sure what temp its set to flow externally
and i dont really understand the wax stat on the front of the piston.
So really, i was just hoping that some on here would pipe in and state the in's and out's of it.
again cheers for the link I will sign up to the site and check it out :wink:
Hillshy
