Author Topic: adding aba oil squirters to 1.6 n/a block  (Read 8616 times)
May 31, 2007, 04:20:26 am
the4ork
  • 331
« on: May 31, 2007, 04:20:26 am »
can i do this? i should be able to just tap them in right?
i got a blown aba block that i can yank the quirters out of... then just throw in some oversized TD pistons and i should be good to go  :wink:
Reply #1May 31, 2007, 12:30:38 pm
Justin
  • 455
« Reply #1 on: May 31, 2007, 12:30:38 pm »
should be able to, I would just take in both blocks to the machine shop so that they can get the proper location  in the block. its pretty much what VW did on all of the turbo blocks, and I could be wrong but I think that the only difference between turbo and non turbo blocks are in fact the oil squirters.
later
Justin
www.archeryprostaffmi.com
Reply #2May 31, 2007, 07:06:13 pm
tylernt
  • 344
« Reply #2 on: May 31, 2007, 07:06:13 pm »
I've heard it said many times that oil squirters can be added to a block but I don't know that anyone has come back and reported success or failure... so please, if you do this, let us know how it works.  :)
Reply #3May 31, 2007, 11:47:32 pm
Audi80
« Reply #3 on: May 31, 2007, 11:47:32 pm »
I´ve done it. We machined squirter places flat and drilled holes. Works fine. I used TD squirters.
Reply #4June 01, 2007, 06:57:02 am
tylernt
  • 344
« Reply #4 on: June 01, 2007, 06:57:02 am »
Quote from: "Audi80"
8)
Reply #5June 01, 2007, 11:06:08 am
subsonic
  • 1836
« Reply #5 on: June 01, 2007, 11:06:08 am »
Quote from: libbybapa
IIRC the gasser squirters squirt at a different pressure than the diesel ones (premature? :lol: ).
Andrew
They have a cream for that now :lol:   :lol:  :lol:
Reply #6January 05, 2009, 07:00:16 pm
Tony2ltr
  • 53
« Reply #6 on: January 05, 2009, 07:00:16 pm »
I am considering doing this becuase I just put the older turbo on an NA engine, but the NA pistons don't have the notches cut out of the skirts. I was just thinking of drilling and tapping for a pipe thread/compression fitting and small tubing that I could bend to shape and then crush the end down for the desired squirt.
What do you think?
-Tony
92 Jetta Ecodzl/biodzl/WVO/meth-H2O turbspray
1969 Subaru 360 Sambar (converted to Electric)
1975 Chevy Cosworth Vega Turboed
1991 Toyota Pickup (megasquirted)
2004 POS Honda Civic (I'll never buy another)
2 cylinder Lister Petter diesel CO-Gen unit
Reply #7January 06, 2009, 06:20:46 pm
Tony2ltr
  • 53
« Reply #7 on: January 06, 2009, 06:20:46 pm »
no kidding?  I never looked at one closely.  I have a TD block, I will take one off and look at it tomorrow.  The only reason I didn't think they would work on a Naturally Aspirated block, is that the Turbo pistons have a notch cut out on the skirt for them.  Maybe I can just modify them and extend the little tubes and make them more of a "U" shape.
I would have nver thought they had little valves in them. Thanks!
-tony
Reply #8January 06, 2009, 07:27:05 pm
« Reply #8 on: January 06, 2009, 07:27:05 pm »
Reply #9January 06, 2009, 07:52:48 pm
blkboostedtruck
  • 1535
« Reply #9 on: January 06, 2009, 07:52:48 pm »
oh JT
that picture turns me on! :twisted:
L.O.L. Duane :roll:
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #10January 06, 2009, 08:32:54 pm
« Reply #10 on: January 06, 2009, 08:32:54 pm »
Quote from: "blkboostedtruck"
oh JT
L.O.L. Duane :roll:
 :lol:
Reply #11January 06, 2009, 08:38:19 pm
VW_Commuter
  • 355
« Reply #11 on: January 06, 2009, 08:38:19 pm »
oh JT
L.O.L. Duane :roll:
ROFLMAO
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #12January 07, 2009, 05:04:54 am
Tony2ltr
  • 53
« Reply #12 on: January 07, 2009, 05:04:54 am »
Yeah Baby! Great pic! where in the world did you find that? Why has the footnote been altered to read 1.5 bar instead of 3 bar?
-Tony
Reply #13January 07, 2009, 09:28:13 am
« Reply #13 on: January 07, 2009, 09:28:13 am »
Quote from: "Tony2ltr"
-Tony
i found an old turbo diesel pdf of a vag manual.  it has the reasoning of why VW/AUDI added turbochargers to their diesel engines.
no clue why they put 1.5 bar from 3 bar...
by chance, does anyone know what the idle oil pressure should be at?  i'm getting 15 psi with the bypass filter and the buzzer isn't coming on... i should be good right? (my oil squirters won't be squirting at idle  :()
Reply #14January 07, 2009, 11:50:51 am
Tony2ltr
  • 53
« Reply #14 on: January 07, 2009, 11:50:51 am »
I believe the part number may be in the now out of print catalogue:
 "2009 FIND OLD JUNK AND TAKE IT APART 1.6"
LOL :lol:
-Tony
