Help me identify a diesel pump
Topic: Help me identify a diesel pump (Read 2788 times)
May 30, 2007, 05:22:47 am
dalek
Newbie
May 30, 2007, 05:22:47 am »
I saved the following pump off the junkyard some time ago. Is it a turbodiesel pump or just a N/A with some weird stuff on it?
Last picture shows the engine code.
May 30, 2007, 06:00:05 am
May 30, 2007, 06:00:05 am »
N/A pumps didn't have the LDA. , so yes, yours is a TD pump.From this thread: "Bosch TD Injection Pump Identification help needed"
Pump #2
0 460 494 162 = VE 4/9 F 2250 R 186 (the same # as your pump)
V: Distributor injection pump
E: Axial piston high pressure pump
4: Number of high pressure outlets
9: Pump plunger diameter in mm.
F: Mechanical governor
2250: Upper pump nominal speed (half of engine rpm)
R: Clockwise (view toward pump drive)
186: Type code
May 30, 2007, 06:22:52 am
VelocityConservation
May 30, 2007, 06:22:52 am »
Quote from: jimfoo
That is not always true. Some US N/A cars had an altitude compensator LDA. This device actually pulls fuel away as the atmospheric pressure drops at altitude. My 90 Jetta had one.
90 TD Jetta, NA to TD swap completed '07
May 30, 2007, 06:38:52 am
Audi80
May 30, 2007, 06:38:52 am »
MF= Golf, Jetta 5/88-10/91 1,6 Turbodiesel 70hp
June 03, 2007, 01:20:08 pm
voodoo
she thinks my tractor's sexy
June 03, 2007, 01:20:08 pm »
that rusty block has piston squirters, suggest to rebuild that block or sell it to one of us just list it we will want it.
June 03, 2007, 02:00:53 pm
June 03, 2007, 02:00:53 pm »
yea a good hot tanking and oversize would make it pretty nice
