Author Topic: VNT Turbo's  (Read 12925 times)
Reply #15May 30, 2007, 02:03:32 pm
Benjamin
  • 485
VNT Turbo's
« Reply #15 on: May 30, 2007, 02:03:32 pm »
understanding turbomaps can also be found here
http://www.turbobygarrett.com/turbobygarrett/tech_center/turbo_tech103.html
i was also thinking those maps should +- the same, but only nobody could say this is a fact.
Greetz, Benjamin
Must make +250hp
Reply #16May 30, 2007, 05:36:07 pm
subsonic
  • 1836
VNT Turbo's
« Reply #16 on: May 30, 2007, 05:36:07 pm »
So with the vnt style of turbo, how do you size one for your application?  If the internals are variable and change to meet load conditions, this changes everything, does'nt it?
Reply #17May 30, 2007, 07:11:14 pm
VNT Turbo's
« Reply #17 on: May 30, 2007, 07:11:14 pm »
No, the variable part is on the exhaust, so it just changes how the turbo spools. The map is for the compressor which will pump x amount of air at y psi pressure when turning z rpm. You would size it like any other turbo. But that is also where vane control comes in, to make sure you stay within the safe area as I believe a VNT is easier to put in the surge zone since it spools faster.
