replacing oil pump - questions!
Topic: replacing oil pump - questions! (Read 6831 times)
May 25, 2007, 07:29:20 am
EatDog
Newbie
May 25, 2007, 07:29:20 am »
Going to replace my oil pump, see if it gives the engine any more pressure (which is very low right now)
Is it a straightforward job.... how many hours work? Is there any issues I need to be aware of? And what is the difference between original and aftermarket parts? (when I've looked for parts, a few different manufacturers are available)
1985 Jetta 1.6TD 499,500km
May 25, 2007, 09:39:51 am
Darth Garry
May 25, 2007, 09:39:51 am »
Before you go tearing into the pump, have you verified without a doubt that the problem is the oil pump? Are you positive it's not an electrical problem? Have you hooked a mechanical oil pressure gauge up anywhere to see how things look?
The actual pump swap shouldn't be too hard. Make sure you get the shaft lined up properly with the keyway in the vacuum pump dizzy. I would recommend sticking with OEM, and perhaps a higher volume pump as an upgrade. Also, some of the different pumps require longer bolts. Make sure you get them if you buy one of the pumps. Check out
www.germanautoparts.com
, they have a good selection.
Oh yeah, this is a good time for an oil pan gasket upgrade too!
Garry
All for one, and one for Awesomeness!
May 25, 2007, 11:55:40 am
EatDog
Newbie
May 25, 2007, 11:55:40 am »
yes i've checked with a mechanical oil pressure gauge
what kind of oil pan gasket upgrade?
May 25, 2007, 01:17:42 pm
subsonic
May 25, 2007, 01:17:42 pm »
Is it mech or hydro? Andrew was kind enough to post the part number for the newer 36mm gear oil pump for the hydro engine. I dont have it with me right now but if you search his posts with the word 36mm it will come up.
1985 VW Golf 5-spd, 4-door, 1.6NA Bought from orig. owner in Savannah with 42,000 miles.
1980 VW Rabbit LS 5-spd, 4-door 1.6NA almost 450,000miles RIP
May 25, 2007, 01:58:14 pm
CoolAirVw
May 25, 2007, 01:58:14 pm »
Here's the thread, I did the search for future generations.
http://www.vwdiesel.net/phpBB/viewtopic.php?t=7071&highlight=36mm
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something
May 25, 2007, 09:02:06 pm
QuickTD
May 25, 2007, 09:02:06 pm »
Quote from: "libbybapa"
Intermediate shaft bearings?
That's where the smart money is. Nothing has an easier life than the oil pump, never seen one wear out. The intermediate shaft bearings, on the other hand, have a hard life and often wear out...
May 25, 2007, 11:10:28 pm
EatDog
Newbie
May 25, 2007, 11:10:28 pm »
Yes I also suspect it's the shaft bearings, in which case I will be shopping for a newer engine. By replacing the oil pump I may just be "delaying the inevitable" but if I can squeeze a few more miles out I'll be pretty happy.
068 115 105ANZ - so this is the 36mm pump that I need? or.. 028 115 105G? (believe this is for the 1.9TD?)
And... any brand, as long as the gears are 36mm in HEIGHT?
I have an '86 1.6TD
May 26, 2007, 09:42:16 am
tylernt
May 26, 2007, 09:42:16 am »
You might need two longer bolts too, as apparently the entire oil pump housing is taller.
November 26, 2007, 12:37:08 am
EatDog
Newbie
November 26, 2007, 12:37:08 am »
Oil pumps do wear out!!!
- I took the pump out and could barely even see the gears, or hear them turning. However, this one had 499,500km on it, assuming it's the original.
Thanks for the help with the part number!
December 01, 2007, 06:23:16 pm
CoolAirVw
December 01, 2007, 06:23:16 pm »
Brand to use is Meyle (oem supplier) Thats the part number from Libbybapa's thread.
Larger gears 36 mm. Note: The smaller gears in the pic is the 30mm pump. Vw's first pump had smaller gears than that. In 85 (I think) oil pumps were upgraded to 30mm.
75 Porsche 914
93 GMC Truck
December 01, 2007, 07:12:10 pm
ilomax
December 01, 2007, 07:12:10 pm »
I swear, this is one of the WORST jobs ever....
I can't stand taking off the oil pan.
What is it, like 29 bolts? Ohhh damn it sucks.
29 damn bolts to take an oil pump out that has two bolts holding it in.
Ohh, you better make sure they are torqued correctly or you'll have some leaks...
I do enjoy having an oil pan baffle.
2001 Audi A8L - Air Ride Suspension - Car PC - 19" Work Equipped Euroline DH - For Sale / $18,000.
1984 Rabbit - Daily driver smoke machine - Can't complain about 23 year old technology that gets 45 MPG.
Reply #11
December 03, 2007, 08:02:05 am
rallydiesel
Reply #11 on:
December 03, 2007, 08:02:05 am »
Will I need longer bolts going from 30 to 36mm? Where would I get these from. There were no bolts with the pump I bought.
1991 Jetta TD - sold
2001 Golf TDI - Son's
Reply #12
December 03, 2007, 03:40:01 pm
rallydiesel
Reply #12 on:
December 03, 2007, 03:40:01 pm »
Does anyone know the part number for the longer bolts?
Reply #13
December 03, 2007, 03:43:17 pm
EatDog
Newbie
Reply #13 on:
December 03, 2007, 03:43:17 pm »
You might not need longer bolts.
I have a 1985 Jetta TD and the bolts fit just fine. If yours is older than 85, it should fit just fine.
I would recommend anyone who's thinking about it, just do it. The pump is quite cheap and it's a 2-minute job once you've got the oil pan off. The oil pan is tricky though, be careful not to strip threads.
Reply #14
December 03, 2007, 03:59:03 pm
rallydiesel
Reply #14 on:
December 03, 2007, 03:59:03 pm »
It's a 1991. Will the bolts be the same? I don't want to take the pan off only to find out my bolts are too short.
