Author Topic: NoObIe question here  (Read 3800 times)
May 24, 2007, 07:21:17 am
Lidoidol
  • 2
« on: May 24, 2007, 07:21:17 am »
Hello all, I have been looking around a bit before posting this so please bear with me if I missed it. My Fiance and I bought a 2006 Jetta TDI last year. We love the car but I want a little more. As you can see from my Sig I am a go hard or go home kind of guy :D  Anyway, I dont want to alter the car too much but I would like a little more spunk.
Basically I would like to pick up a few ponies, while keeping my current mileage if not improving it. Could someone give me some pointers as to where to begin? I am very new to Veedubs, and fairly new to diesels so all my experience with cars is pretty much useless :lol:
Thanks
Keith
PS - I am an ASE master tech, as well as certified master fabricator/welder, so you can give it to me straight :)
If it ain't got boost, get out of my way
2006 Jetta TDI
2006 F150 STX V6 - Remote mount turbo
1987 Mitsu Starion - arias, saenz, stroked to 2.8, sheet metal intake, Holset HX50 623whp
1987 Mitsu Starion - 4G63/'Glide/9" lookin for 8's
1976 F150 Big Block, 38's
Reply #1May 24, 2007, 07:33:22 am
« Reply #1 on: May 24, 2007, 07:33:22 am »
well you should probably do the EGR delete... as every EGR equipped car has a gunked up intake manifold, and even the head is a bit gunked up as well...
Reply #2May 24, 2007, 07:54:16 am
« Reply #2 on: May 24, 2007, 07:54:16 am »
But if you have an emissions inspection, you may not pass if you touch the EGR. I know there are performance chips, maybe programmers for TDIs.
Reply #3May 24, 2007, 08:35:09 am
Lidoidol
  • 2
« Reply #3 on: May 24, 2007, 08:35:09 am »
Quote from: jtanguay
is there a write up on this anywhere??
2006 Jetta TDI
Reply #4May 24, 2007, 08:38:46 am
« Reply #4 on: May 24, 2007, 08:38:46 am »
I read something, maybe under the TDI section. Just put a similarly shaped steel plate over where it was, plug the vacuum line and unplug the wires. Guess it would be easy enough to reinstall if needed.
Reply #5May 24, 2007, 08:40:14 am
« Reply #5 on: May 24, 2007, 08:40:14 am »
It was here, though on an IDI engine. http://vwdiesel.net/phpBB/viewtopic.php?t=8380
Reply #6May 24, 2007, 08:43:48 am
rallydiesel
  • 1880
« Reply #6 on: May 24, 2007, 08:43:48 am »
You need to go to http://www.tdiclub.com/
As far as the best mod for you, I would recommend the Diesel Power Digi PD  tuning box. It is a simple plug in unit that alters your fueling and has no effect on fuel economy. It is also easily removed for warranty work. Anything more aggressive and you will need a different clutch/flywheel.
Here is their website:
http://www.dieseltuning.ca/modules/digipd.html
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #7May 24, 2007, 08:01:33 pm
« Reply #7 on: May 24, 2007, 08:01:33 pm »
hmmm yea... i know here in Canada nobody really tests diesels because we don't have the equipment... i guess if the guy's wanted to be real dicks they could check for a cat and for the EGR device... but if you put a nice block off plate nobody will know  :wink:
i wish i had a pic of a gunked up head for you... that stuff is nasty!
