Author Topic: 020 transmission flange seal size  (Read 3971 times)
May 19, 2007, 04:18:18 am
Zulfiqar
  • 254
« on: May 19, 2007, 04:18:18 am »
Hi,
Im about to replace my clutch disc, and Ive also seen that both flange seals are leaking, Ive arranged a clutch disc and pressure plate, but I dont have the flange seals.
If any of you people know that seal sizes, (theyre stamped on the seals themselves) please post them up, because as this golf is my daily driver, it would take me forever to find the seals as I have a tight working schedule.
If I knew the sizes I would just go and buy them from a seal specialty shop.
Diesel IS the future
Reply #1May 19, 2007, 05:55:10 am
« Reply #1 on: May 19, 2007, 05:55:10 am »
I'll try to remeber to check tonight
Reply #2May 19, 2007, 06:57:57 am
Zulfiqar
  • 254
« Reply #2 on: May 19, 2007, 06:57:57 am »
thanks - ill be waiting.
if you can eyeball the selector eyelet shaft seal also - it'll be great
Reply #3May 19, 2007, 08:55:45 am
rallydiesel
  • 1880
« Reply #3 on: May 19, 2007, 08:55:45 am »
This is what is stamped on my new set:
DGS 50 - 65 - 10 WDF01
It also says KACO    33 on the other side.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4May 19, 2007, 09:32:02 am
Op-Ivy
  • 513
« Reply #4 on: May 19, 2007, 09:32:02 am »
http://scirocco.org/gears/
At the bottom of the page check your tranny code then the flange size.
Mine are the 90mm. I would assume most diesel ones are as well.
Reply #5May 19, 2007, 09:33:30 am
Zulfiqar
  • 254
« Reply #5 on: May 19, 2007, 09:33:30 am »
excellent
so its 10mm wide, 65mm outer collar, 50mm inner lip. (it should be directional also)
Great, thanks a million
op ivy -checked the box, its an ACH tranny 90 mm flanges.
Reply #6May 19, 2007, 09:52:37 am
rallydiesel
  • 1880
« Reply #6 on: May 19, 2007, 09:52:37 am »
Yes, there were arrows pointing both ways.
