Author Topic: FS Hard injector lines  (Read 11014 times)
Reply #15May 18, 2007, 03:32:33 pm
« Reply #15 on: May 18, 2007, 03:32:33 pm »
I'll just compare them to my lines, thanks for clarifying that 8)
Reply #16May 20, 2007, 11:21:51 am
blkboostedtruck
  • 1535
« Reply #16 on: May 20, 2007, 11:21:51 am »
i know the answer to this question- the two lines that go behind the turbo injector pump are different from n/a diesel ! the extra bends allow clearance when adjusting the TD pump but say if a line fails you can use a n/a diesel line it will work to get you by but you wont be able to adjust the pump for timing purposes ! i'm using a n/a diesel line on my turbo diesel motor now becase one of my lines cracked on the #1 cylinder! also i'm not sure but i believe that the TD lines have a bigger ID than the n/a diesel lines for the more fuel delivery but i could be mistaken !! i've never measured the difference but would sure would like to know if anyone has the equipment or knowledge about that? thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #17May 21, 2007, 05:52:59 pm
« Reply #17 on: May 21, 2007, 05:52:59 pm »
All 3 sets are TD
Reply #18May 21, 2007, 10:01:50 pm
blkboostedtruck
  • 1535
« Reply #18 on: May 21, 2007, 10:01:50 pm »
i read what the difference is between them! the TD lines have a bigger I.D and are longer then the n/a diesel lines ! because of the higher fuel pressure  /bar at the TD injector! you can put a n/a line on a td to get you by till you find the correct one . i know it works because i have the one on my td and it's behind the LDA you cant adjust the pump timing with it on though! if any body wants i can look it up again and post the proper measurements if anyone wants ? thanks Duane
'66 variant 1500S
Reply #19May 22, 2007, 02:37:23 pm
blkboostedtruck
  • 1535
« Reply #19 on: May 22, 2007, 02:37:23 pm »
I would be interested in buying your 3 sets of turbo inj. lines as long as they are tru td lines and not mixed with n/a lines shoot me a pm and we will work out the details thanks Duane
'66 variant 1500S
Reply #20May 22, 2007, 11:30:38 pm
« Reply #20 on: May 22, 2007, 11:30:38 pm »
Turns out the set on my car decided to explode, thankfully I made it home from my road trip, although the mileage wasn't that good.
I think I already have the sets sold, well at least tentivily. I"ll get more though
Reply #21May 23, 2007, 12:07:13 am
blkboostedtruck
  • 1535
« Reply #21 on: May 23, 2007, 12:07:13 am »
well i can definatly use one set now ! i'd like to get the n/a lines off of my truck and get back the way it should be!i've noticed lately  it don't sound right with them on ! well let me know what you come up with i would appreciate it thanks Duane
'66 variant 1500S
Reply #22May 24, 2007, 07:41:31 am
« Reply #22 on: May 24, 2007, 07:41:31 am »
Here are the long awaited pictures. I used the worse looking set (not pictured) on my own car and it's working great.
BTW my old broken set is for sale for $15. It may be fine because after installing the "new" set I realized that the 12mm timing hole bolt had backed out. There is a mark on the #4 line though, it will definitly fail soon if it hasn't already but the other 3 look fine.
Reply #23May 24, 2007, 07:54:46 am
blkboostedtruck
  • 1535
« Reply #23 on: May 24, 2007, 07:54:46 am »
so Tyler is that 2 sets and your broken one for sale? i'll take all that you have to offer ! do you have a paypal account? got an idea of shipping to 53221 ?
 thanks Duane
'66 variant 1500S
Reply #24May 24, 2007, 08:51:37 pm
« Reply #24 on: May 24, 2007, 08:51:37 pm »
I think all the ones pictured are sold, except for my broken set which is not pictured (yet).
I'll have more lines shortly though, within 2 weeks hopefully
Reply #25May 25, 2007, 08:01:33 am
blkboostedtruck
  • 1535
« Reply #25 on: May 25, 2007, 08:01:33 am »
well keep me posted  if someone backs out or you get more i'll even buy your broken set from you !! thanks Duane
'66 variant 1500S
Reply #26May 25, 2007, 08:54:51 am
« Reply #26 on: May 25, 2007, 08:54:51 am »
Will do. You're next in line. How many sets do you need?
Reply #27May 25, 2007, 12:09:31 pm
blkboostedtruck
  • 1535
« Reply #27 on: May 25, 2007, 12:09:31 pm »
at least 2 sets and i will take your broken set too i think i can make a good set out of that the one yours is broke is the only one i got good left on mine that is good out of the TD set that came on my engine . do you think or know if 1.9 TD injector lines will fit on a 1.6TD engine? i don't have a set to expierament with? thanks tyler let me know what you find out or come up with ? and how do you want to make the transaction? i'm also looking for a mk2 diesel tach for my pickup do you have any leads on one? thanks Duane
'66 variant 1500S
Reply #28May 26, 2007, 09:12:11 am
« Reply #28 on: May 26, 2007, 09:12:11 am »
1.9 lines won't work on a 1.6, they are too high due to the taller injectors on a 1.9.
paypal, money order, check.. it's all good for payment
I have a couple clusters with tachs, all mk2 though... well I have 1 from a mk1 Jetta diesel but I don't know if it works. I think it is just a gasser tach thrown into the diesel cluster
Reply #29May 27, 2007, 02:11:56 pm
blkboostedtruck
  • 1535
« Reply #29 on: May 27, 2007, 02:11:56 pm »
how much are you asking for a mk2 tach ? i have a cluster i can put it in here   or if maybe you have a cluster that the speedo side don't work
 and i have 4or 5 mk1 gas clusters with tach but in order to make a gasser tach you half to do some soldering in of other resistors and callibrate the tach after the modification works been done! too much of a pain for me to do and not much of an electrition either ! so i just want to find one from an early diesel mk2 golf or jetta that used the W terminal . makes it so much simpler for me! so how ever you want to sell it for me as long as i end up with a correct mk2 diesel tach? i think they even say diesel on the face? well let me know and also about the td injector lines when you got somemore to sell
 thanks Duane
'66 variant 1500S
