Used (working) ones are not as easily attainable as one would think and I just can't go on a chaise to save a few bucks.
Try Frisco auto parts: call (416) 736-9595 ask for Henry. I'm pretty sure he has some.
after spending nearly $3500 on a $5000 car...I can finally drive a reliable car.
wow, man, that's a lot of dough for an 11 year old car with 210,000km on it. For $8500 you could almost get a new car (I think the entry price right now for a brand new econobox is $10,000). Just to p*ss you off further, and because I love playing devil's advocate (or at least, letting people know things they'd rather not know), old high mileage diesels that leak oil, generally do so because they have a lot of blow by past the rings, and the crankcase gets pressurized, pushing the oil out. This is because diesels operate at positive pressure (ie, they always suck in as much air as they can get) and have no engine vacuum. Turbo diesels are particularly bad for this because of the added psi that the turbo pumps into the cylinders. Maybe get your mechanic to do a quick compression test on your engine before you spend too much more money. You might get a shock. A diesel engine with good rings usually won't leak any oil, even if some of the seals are questionable. Exception to this is the valve cover gasket, which almost always leaks at the back.
