Author Topic: 11mm pump head on TDI 1z engine  (Read 4154 times)
May 09, 2007, 06:12:32 am
Ray_G
  • 1
« on: May 09, 2007, 06:12:32 am »
I want to put an 11mm pump head on one of my Passat's. I can remove and reinstall the pump heads no problem, have resealed quite a few lately. There is what the local Bosch shop refers to as a "timing shim" that goes between the cam plate and pump shaft. They come in different thicknesses. I am not sure the exact purpose of them is, (well I can guess) but if I put an 11mm head on my existing pump how would I figure out what thickness shim would be required? Would I just use the one that is in there now. Also I saw an old link to a Bosch manual for these pumps, it is dead now. Does anyone have a link to one, or can send me one.
 Thanks,
 Ray
Reply #1May 13, 2007, 10:05:54 am
Wingaman
  • 7363
    • http://www.dmfdiesel.com
« Reply #1 on: May 13, 2007, 10:05:54 am »
They are noi "K Quote" for the TDI pump. So you dont need to change the start injection shim.
Just reuse de same
371-B, Ch. Ste-Marie
Ste-Marthe QC J0P 1W0
Reply #2May 13, 2007, 12:09:05 pm
Tintin
  • 1279
« Reply #2 on: May 13, 2007, 12:09:05 pm »
Only for the original 11mm TDI pump and some other,  it do not have Cote ''K'' ,  it's ''K1''.
The timing with the shim between the plungeur and the came plate is for the old plunger with a groove at the end of the plunger,  same as cummins 337 H&R, but, it's important to put the proper shim when you install all H&R, to make sure that the plunger do not touch on the timing plug at high RPM.
Reply #3May 13, 2007, 08:43:59 pm
« Reply #3 on: May 13, 2007, 08:43:59 pm »
Quote from: "Tintin"
you are very knowledgeable named TinTin!
get some good carnage if the plunger hits the timing plug!  :shock:
