Author Topic: Turbo surge protector..??  (Read 25462 times)
Reply #30June 24, 2007, 09:58:33 am
OM617
« Reply #30 on: June 24, 2007, 09:58:33 am »
Pretty much every stock diesel on the market will do that (Especially the Dodge/GM/Ford pickups in the states), it's considered normal and not really harmful.
Reply #31June 24, 2007, 09:43:17 pm
shadowmaker
  • 28
« Reply #31 on: June 24, 2007, 09:43:17 pm »
Quote from: Benjamin
when i pull to full boost, and i release on a high rpm, my turbo makes dumpvalve sound, is that surge also? Do i need to use a dieseldumpvalve?
now the vnt is even not fulle adjusted, the vanes dont close much when offboost.
Greetz, Benjamin
No, that's normal when you are using high boost. Surge is a chattering sound and you can hear it very clearly at first and then it fades away. It's like TSAT-tsat-TSAT-tsat-TSAT-tsat
2.5TDI 5cyl with 227,7kW and 586,6Nm @ 1,3bar (2??kW @2,0bar)
14,53s 158,88kmh @ 1/4-mile
1980kg with aerodynamics of a barn door
http://www.youtube.com/watch?v=hkSTslJf7Z4
Reply #32July 01, 2007, 03:22:36 pm
« Reply #32 on: July 01, 2007, 03:22:36 pm »
Quote from: "OM617"
If it isn't harmful then why would manufacturers bother spending the time and money to design surge protection into turbos? It puts a lot of stress on the turbo.
Reply #33July 03, 2007, 10:38:27 pm
hillfolk'r
  • 1532
« Reply #33 on: July 03, 2007, 10:38:27 pm »
Quote from: shadowmaker
Greetz, Benjamin
to me that is the mostest coolest sound,lol
i make mine do it on purpose,sorta
wind it out in a gear,lots of boost....then push in the clutch,and shift grandma slow,,you get the chuffin sound
it sounds like rapid flatuation,,lol
 :lol:  :lol:
Throttle cables ftw
Reply #34July 04, 2007, 11:53:58 am
ezekiel
  • 147
« Reply #34 on: July 04, 2007, 11:53:58 am »
Quote from: OM617
 :shock:  :shock:
surge, not good in any way, shape, or form.
It's like spinning a bike wheel up and then shoving a stick in the spokes.
and hillfolk, that'd explain why your turbos blow so fast  :wink:
Reply #35July 04, 2007, 12:07:33 pm
Benjamin
  • 485
« Reply #35 on: July 04, 2007, 12:07:33 pm »
Quote from: "ezekiel"
Quote from: "OM617"
 :shock:  :shock:
it was an answer to my quistion, we'r not talking about surge
Greetz, Benjamin
Must make +250hp
Reply #36July 04, 2007, 12:45:03 pm
ezekiel
  • 147
« Reply #36 on: July 04, 2007, 12:45:03 pm »
oh ok, didn't read back any, my fault.
Reply #37July 04, 2007, 02:39:32 pm
hillfolk'r
  • 1532
« Reply #37 on: July 04, 2007, 02:39:32 pm »
Quote from: ezekiel
Quote from: OM617
 :shock:  :shock:
one of the garretts blew a the exhaust wheel right out of the dp at the  drags at the 1000 foot mark
one of the kkk's let that lame thrust bearing go at hi revs+pumped about 1 qt  of oil in the intake
so no that doesnt explain why im blowing turbos
maybe its because i let   them go full  boost(40+psi) ,and im seeing 1500degree exhaust temps
the turbine  wheels are literaly melting off ,or getting fatigued
Throttle cables ftw
