Author Topic: Quick Metal HG on 1.6 TD hydro question  (Read 3642 times)
April 26, 2007, 08:05:48 pm
rallydiesel
  • 1880
« on: April 26, 2007, 08:05:48 pm »
I am getting confused. Do you need to plug any holes if using a metal 1.9 head gasket on a 1.6 TD engine with hydraulic cam followers? If yes, which holes and how do you do it?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #1April 27, 2007, 08:01:06 am
« Reply #1 on: April 27, 2007, 08:01:06 am »
I may be a bit of a newbie but it seems to me this subject comes up allot.
I have read every damn post I can find on the metal head gasket and the non hydro block to the hydro head swap and I'm still confused....
From the quantity of posts on the subject I would dare to guess I'm not the only one.
Reply #2April 27, 2007, 01:57:25 pm
« Reply #2 on: April 27, 2007, 01:57:25 pm »
so it can be made straight, this is the facts on using a metal head gasket
for a full hydro lifter 1.6:
the metal headgasket goes right in, just like the normal gasket
for a solid lifter block with a solid lifter head:
you just have to block off the coolant passage, you can either drill it out to be round and plug it, or do like Audi80 did and cut a piece of rubber to fit where the leak would occur
Quote from: Audi80
I blocked the hole with 2mm rubber. I did not drill those 8 holes, why should?
for a solid lifter block with a hydro head:
you must plug the water passage in the block, and the extra oil drain the head.  or you can  just plug the head, then have it planed flat, then use a piece of rubber like Audi80 did.
Reply #3April 27, 2007, 06:02:44 pm
rallydiesel
  • 1880
« Reply #3 on: April 27, 2007, 06:02:44 pm »
I agree. Just another question, how do you bleed the blinker fluid and does anyone have a source for muffler bearings?
Reply #4April 27, 2007, 07:10:18 pm
« Reply #4 on: April 27, 2007, 07:10:18 pm »
Quote from: rallydiesel
haha i go to a vocational high school for electronic repair and all the kids from automotive shops try to get people with that stuff.  those guys are dopes, alot of them don't know *** about cars.  anyways... just thought i'd share
