Author Topic: Good find ? Hope so.  (Read 4810 times)
April 06, 2007, 08:12:49 pm
« on: April 06, 2007, 08:12:49 pm »
I found a local guy with a what looks to be complete 1.6 turbo engine.
Solid lifter head.
The block is going to need to be rebuild and the head will be replaced, it looks like the idler shaft pulley worked loose and allowed the timing belt to jump a few teeth causing the pistons to contact the valves for a long time, the valves actually embedded them self's in the pistons, I mean they hit enough times there is aluminum mushrooming out from the impact areas.
The head is also cracked between one of the valves and a precup. it also looks like it may have had to thin of a head gasket on it because it looks like the pistons made contact with the precup area also.
Anyway, I walked away with all the turbo components and a good base to build off for $100.00.
Question, can I use my NA solid lifter head if I have it fitted with turbo exhaust valves? I have what I think is a good solid head and a good hydro head as well.
I guess I could just have the solid turbo head tested before I bail on it, the crack may be just in the surface.
I'm excited just the same. Gonna get the pump off to Giles and do a rebuild on the bottom end, should be fun when I'm done.
Reply #1April 06, 2007, 09:39:23 pm
Re: Good find ? Hope so.
« Reply #1 on: April 06, 2007, 09:39:23 pm »
Quote from: "zukgod1"
Solid lifter head.
i think the solid lifter N/A heads are inferior to the TD solid lifter & hydro heads.  (both N/A and turbo hydro heads have the same p/n's)
Reply #2April 08, 2007, 11:01:25 am
« Reply #2 on: April 08, 2007, 11:01:25 am »
[/quote]
i think the solid lifter N/A heads are inferior to the TD solid lifter & hydro heads.  (both N/A and turbo hydro heads have the same p/n's)[/quote]
How is that possible?
They are the same casting so besides the valves and cam grind what else could be different?
Reply #3April 08, 2007, 02:25:31 pm
« Reply #3 on: April 08, 2007, 02:25:31 pm »
Reply #4April 08, 2007, 09:19:09 pm
« Reply #4 on: April 08, 2007, 09:19:09 pm »
Ok, so as I stated the valves are differant.
Injectors are no biggie, have them out of the turbo head and the NA hydro head.
Bigger bolts? machine shop can fix that, again no big deal.
Reply #5April 09, 2007, 05:39:36 am
« Reply #5 on: April 09, 2007, 05:39:36 am »
Being a TD that engine should have 12mm bolts alreaady although I have been wrong before.
I'd imagine that the crack is superficial but definitly have it tested. I have a solid lifter block that I'll be parting out if there is anything good in it. The guy pulled the injectors a year years back and it's just been sitting in the car :roll:
Reply #6April 09, 2007, 07:21:35 am
« Reply #6 on: April 09, 2007, 07:21:35 am »
Quote from: burn_your_money
Ya, I'll have it tested for sure. I actually have three solid heads but only one is Turbo. Both the NA heads are in good shape. As is the Hydro head.
That's the head I would really like to use but I'm not that excited about having the extra hole plugged, just seems like to much of a possible failure area in the future.
Reply #7April 09, 2007, 01:15:13 pm
« Reply #7 on: April 09, 2007, 01:15:13 pm »
the extra hole is probably just for extra oil pressure for the hydraulic lifters.
the picture i have shown indicates the changes that VW made to incorporate the turbocharger.  Mech TD heads have all of those changes (12mm head bolts etc) but mech n/a heads do not.
Reply #8April 10, 2007, 06:22:04 pm
« Reply #8 on: April 10, 2007, 06:22:04 pm »
i thought the bumped injection pressure was due to longer fuel lines... but i never had a source?
Reply #9April 10, 2007, 06:34:37 pm
« Reply #9 on: April 10, 2007, 06:34:37 pm »
should b from the camplate lift
