Author Topic: AAZ Governer mod  (Read 4121 times)
March 18, 2007, 05:15:56 am
Jimmy Diesel Junior
  • 64
AAZ Governer mod
« on: March 18, 2007, 05:15:56 am »
Hi all. I've been trawling the search forums to find out about the governer mod on my aaz. Any of the posts i've seen are for the 1.6 td pump. Is the method of modding the governer on the aaz pump the very same??? I am aware or the use of the aneroid pin from the 1.6 in the 1.9. Thanks guys  :lol:
PEACE THROUGH SUPERIOR HORSE POWER
Reply #1March 18, 2007, 05:23:23 am
AAZ Governer mod
« Reply #1 on: March 18, 2007, 05:23:23 am »
yes it's the same
Reply #2March 18, 2007, 09:27:11 am
DVST8R
  • 535
AAZ Governer mod
« Reply #2 on: March 18, 2007, 09:27:11 am »
Well mostly the same, the aaz pumps are a little more complicated inside. It has been ahwile, but i think it has to do with the gov setup on the aaz pump being a bit different. Maybe some one who has pulled one apart more recently then myslef can chime in here.
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #3March 18, 2007, 09:36:09 am
AAZ gov mod
« Reply #3 on: March 18, 2007, 09:36:09 am »
Too bad I didn't take pics. Yeah, there is one spring that is different in that it is external to the rest of the governor, not on the shaft. Everything else looked the same. Make sure to mark the position of the throttle shaft, which if yours is like mine, has to be marked after taking off the first spring. It doesn't have the hash marks like in the gov mod pics. all the springs were a *** to get back on. I had the best success using some MIG wire wrapped on a bolt and a very small nut driver to pull and push them back into place.
Reply #4March 18, 2007, 09:50:47 am
Audi80
AAZ Governer mod
« Reply #4 on: March 18, 2007, 09:50:47 am »
It is same as later 1,6. Idle spring? is located differently.
Reply #5March 18, 2007, 09:53:43 am
AAZ Governer mod
« Reply #5 on: March 18, 2007, 09:53:43 am »
Yeah, that's what mine looked like.
Reply #6March 18, 2007, 09:55:01 am
AAZ Governer mod
« Reply #6 on: March 18, 2007, 09:55:01 am »
Thanks for the pictures.... always worth a thousand words.
I've got a NA practice pump before I tear into my real pump so I don't have the spring that shows in your second picture... but I will when I do it for real.
Where does that little spring attach ??
thanks,
Reply #7March 18, 2007, 12:08:15 pm
AAZ Governer mod
« Reply #7 on: March 18, 2007, 12:08:15 pm »
It attaches to the governor. You'll see when you take it apart.
Reply #8March 18, 2007, 03:13:53 pm
Benjamin
  • 485
AAZ Governer mod
« Reply #8 on: March 18, 2007, 03:13:53 pm »
Quote from: Audi80
well well...
thats why i lost my spring... it was never in there  :D
i saw this when i did my governermod, becouse i was afraid of the idle i placed the 3th spring like the other pic's do have. my engine run fine with 2 springs  :oops:
Greetz, Benjamin
EDIT: whats the best idle system anyway? (or whats a benefit or so)
this one
or this one:
1 2
why did they make a difrence
Must make +250hp
Reply #9March 19, 2007, 08:03:58 am
Jimmy Diesel Junior
  • 64
AAZ Governer mod
« Reply #9 on: March 19, 2007, 08:03:58 am »
Hi again all. I'm starting to think that it may be better to use the 1.6 td pump in place of the aaz pump. Is this wise or rediculous??? :shock:  The reason that i ask this is the following... I'd be pulling the 1.6td pump apart for the aneroid pin anyway and if the governer mod is easier on the 1.6td pump then why not just use that?? Any advice greatly appreciated guys.. Cheers  Shane
Reply #10March 19, 2007, 09:48:01 am
Jimmy Diesel Junior
  • 64
AAZ Governer mod
« Reply #10 on: March 19, 2007, 09:48:01 am »
Anyone  :?:
Reply #11March 19, 2007, 01:24:16 pm
Jimmy Diesel Junior
  • 64
AAZ Governer mod
« Reply #11 on: March 19, 2007, 01:24:16 pm »
Does anyone know if it'd be easier for me to use the 1.6 td pump on my aaz?? Please help because i was hoping to start on this tomorrow. Thanks.. Shane
Reply #12March 19, 2007, 08:41:32 pm
AAZ Governer mod
« Reply #12 on: March 19, 2007, 08:41:32 pm »
The mod really shouldn't be any harder on the aaz pump. I'd use it
Reply #13March 19, 2007, 11:51:44 pm
Jimmy Diesel Junior
  • 64
AAZ Governer mod
« Reply #13 on: March 19, 2007, 11:51:44 pm »
Thanks jimfoo.. Anyone else???
