Author Topic: New here.  (Read 5935 times)
December 01, 2004, 09:54:20 am
m.diesel
  • 3
New here.
« on: December 01, 2004, 09:54:20 am »
I just found this site and wanted to say hello to everyone.  After looking around a bit I didn't see a lot about the pd-tdi's.  Is this site for older tdi's only? Or are the pd's still too new in NA?
Anyone from Pa on here?
1.9 liters of oil burnin fury!
Reply #1December 01, 2004, 10:43:49 am
Justin
  • 455
New here.
« Reply #1 on: December 01, 2004, 10:43:49 am »
welcome
this is for the older Naturally Aspirated In Direct Injection engines as well as the TD's and TDI's
what is this  pd that you speak of??
www.archeryprostaffmi.com
Reply #2December 01, 2004, 11:05:00 am
m.diesel
  • 3
New here.
« Reply #2 on: December 01, 2004, 11:05:00 am »
pd (pumpe dusse) is the new tdi engine.  Still 1.9 liters, but with a different fuel pump(s) and injection set-up.  The rotary pump is gone and has been replaced by "unit injectors" or basically there's a little fuel pump at each injector.  Stock power is up to 100hp and 177lbft, it meets tier II emissions requirements, it's a little quieter, it's a little smoother, but fuel mileage is down 2-4mpg.
Reply #3December 01, 2004, 11:23:50 am
MacGyver
  • 245
New here.
« Reply #3 on: December 01, 2004, 11:23:50 am »
The most direct source of info on PD's I know of is @ www.tdiclub.com , particularly this forum:
http://forums.tdiclub.com/postlist.php?Cat=0&Board=PDTDI
Reply #4December 01, 2004, 12:04:50 pm
m.diesel
  • 3
New here.
« Reply #4 on: December 01, 2004, 12:04:50 pm »
Yeah, I've been a member of tdiclub for about a year or so.  Some good info there.
