S-PAutomotive.com
Author Topic: Headgasket Sizes / Part Numbers  (Read 23552 times)
February 13, 2007, 01:54:24 pm
  • Administrator
  • 1156
    • Malone Tuning Ltd.
« on: February 13, 2007, 01:54:24 pm »
Thanks go to fspGTD for retrieving this information:
1.6L
1980 Rabbit 1.6D:
* 3-notch (1.4mm): 068 103 383 FB
* 4-notch (1.5mm): 068 103 383 FC
* 5-notch (1.6mm): 068 103 383 FD
1981 Rabbit 1.6lD 11mm headbolt:
* 1-notch (1.4mm): 068 103 383 ES
* 2-notch (1.5mm) 068 103 383 ET
* 3-notch (1.6mm): 068 103 383 FA
81-84 Rabbit/Jetta 1.6 solid lifter 12mm headbolt:
* 1-notch (1.4mm): 068 103 383 FL
* 2-notch (1.53mm) 068 103 383 FM
* 3 notch (1.61mm): 058 103 383 FN
1986 Jetta 1.6 hydraulic:
* 1-hole (1.53mm): 068 103 383 EH
* 2-hole (1.57mm): 068 103 383 EJ
* 3-hole (1.61mm): 068 103 383 EK
The 11mm headbolt Vanagon CS engine code did get a unique head gasket:
1980-85 Vanagon 1.6 11mm headbolt (up to CS 000 338):
* 1-notch (1.4mm): 068 103 383 AT
* 2-notch (1.5mm): 068 103 383 ET
Engine code JX:
* 1-hole (1.53mm): 068 103 383 FE
* 2-hole (1.57mm): 068 103 383 FF
* 3-hole (1.61mm): 068 103 383 FG
1.9L
1 hole (1.53mm) 028 103 383BH
2 hole (1.57mm) 028 103 383BJ
3 hole (1.61mm) 028 103 383BK
I don't have ETKA handy at the moment.. If anyone has more headgasket information to share, please post here or send me a PM.
« Last Edit: February 09, 2022, 06:04:11 pm by libbydiesel »
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #1January 03, 2008, 07:06:51 pm
dieselsnowmobile
  • 103
« Reply #1 on: January 03, 2008, 07:06:51 pm »
Engine codes with them?
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
Reply #2January 05, 2008, 02:24:22 am
  • 9005
« Reply #2 on: January 05, 2008, 02:24:22 am »
Quote from: "prothe"
What's the difference between the 80 and 81 Rabbit?
It looks like VW just changed their rating system (number of notches) because the thickness stayed the same, only the suffix on the part number changed
Looking at the part numbers they all end in 383 except for 3 of them, where it is 838, is that a typo?
Reply #3January 14, 2008, 05:20:07 pm
  • 5064
« Reply #3 on: January 14, 2008, 05:20:07 pm »
what about tdi?  i've been wondering if i could just use a tdi head gasket on my 1.6
Reply #4January 14, 2008, 05:43:18 pm
« Reply #4 on: January 14, 2008, 05:43:18 pm »
Well if the TDI head, at least up to AHU, fits an AAZ, and an AAZ gasket fits a 1.6, then a TDI gasket fits a 1.6 as well.
Reply #5January 31, 2008, 10:05:14 pm
Vanagoner
  • 219
« Reply #5 on: January 31, 2008, 10:05:14 pm »
Are all of the CS blocks tapped for 11mm headbolts? argh. I assumed it was a 12mm engine.  Why would they do that- Vanagon engines are chronically overstressed.
Sage
Reply #6November 13, 2008, 01:51:04 pm
53 willys
« Reply #6 on: November 13, 2008, 01:51:04 pm »
Quote from: "jimfoo"
yeah  but what about the AHU gasket not having prechamber reinforcements??? that's the only difference I can see between the two engines....
Reply #7November 15, 2008, 11:17:50 am
Reply #8February 06, 2009, 07:50:19 am
myke_w
  • 1099
« Reply #8 on: February 06, 2009, 07:50:19 am »
just to add some redundancy (grabbed from brick's website)
1 notch - 1.53mm thick to suit piston protrusion of .66mm to .86mm
2 notch - 1.57mm thick to suit piston protrusion of .87mm to .92mm
3 notch - 1.61mm thick to suit piston protrusion of .93mm to 1.02mm
Reply #9August 14, 2018, 07:28:40 pm
  • 3416
Re: Headgasket Sizes / Part Numbers
« Reply #9 on: August 14, 2018, 07:28:40 pm »
Here are the 1.5L sizes:
piston protrusion     gasket thickness     notches     part number
0.43-0.63(.017-.025)     1.30(.051)     2     068103383
0.63-0.82(.025-.032)     1.40(.055)     3     068103383C
0.82-0.92(.032-.036)     1.50(.059)     4     068103383G
0.92-1.02(.036-.040)     1.60(.063)     5     068103383H
Fixmyvw.com
