VWDiesel Blog
Facebook Group
VWD on Twitter
mTDI Mechanical TDI Conversions
m pump
Topic: m pump (Read 9261 times)
February 03, 2007, 04:46:04 am
snakemaster
m pump
February 03, 2007, 04:46:04 am »
put a M pump on my tdi and runs good bit i only have the std 90hp.185 injectors the prob is if give it hard throtle the car goes down to 3 clinders then 2 and after 30 meters with light throtle it goes back on to 4 clinders, and then it goes good with stedy throtle, any though on what is causing this :? i have the gov mod on the pump to , it even done it with the fly by wire pump
Glenmorangie single highland malt
February 03, 2007, 08:58:35 am
Slave2School
m pump
February 03, 2007, 08:58:35 am »
Are the injectors all tightened in enough/clean at the base? Mine was pretty slow when I had a slight leak on two cylinders. Some soapy water at idle might show if there are any leaks around the injectors or the glow plugs.
2002 ford focme wagon
February 03, 2007, 10:22:29 pm
craiggroombridge
User+
m pump
February 03, 2007, 10:22:29 pm »
sounds like a supply restriction check your fuel volume
Craig
My first was an 85 gas fun
my second is an 86 gas more fun
my third is a 92 n/a diesel project
February 04, 2007, 07:32:45 am
Ziptar
m pump
February 04, 2007, 07:32:45 am »
Might be because your avatar is so huge...
Really though... sounds like air is getting sucked into the fuel lines before the IP somewhere or you have a blockage / clog.
If you left it sit for a while does it also take some cranking to get it going again? In otherwords has fuel drained back to the tank?
I had almost the exact same problem on my 03 TDI a couple years back....
Went crazy all day Mity-Vac'ing all the lines and checking injectors only to find a seam had failed on the fuel filter after 8000 miles. It was a small hair line leak at the seam but, was enough to be problem.
February 04, 2007, 11:57:40 am
Tintin
m pump
February 04, 2007, 11:57:40 am »
I wants to understand well, if i translated correctly, that gives me the effect of a timing too retard with a came plate not enough aggressive.
Here i see some TDI with AAZ pumps, and it is the same thing which occurs.
February 04, 2007, 01:56:22 pm
snakemaster
m pump
February 04, 2007, 01:56:22 pm »
Well i dont think it is puling in air to the diesel system , car got std turbo with no pipe going to the wast gate so runs max boost 22psi , and the car only goes down 3 cilenders in 1and 2 gear under hard throtel and the rest of the time ok , going to put .216 nozzels and a biger turbo in the next few months
February 06, 2007, 04:14:38 pm
snakemaster
m pump
February 06, 2007, 04:14:38 pm »
pic of my Mtdi worse for ware :roll:
[/img] thats a perkins primi pump with a spacer plate i made up
[/img]
February 07, 2007, 12:50:58 am
hillfolk'r
m pump
February 07, 2007, 12:50:58 am »
try a lift pump back at the tank
i mean a pump(at the tank) to supply fuel to the IP
my car used to"lay down" in the higher gears before i used a supply pump to bring fuel to the front of the car
Throttle cables ftw
February 07, 2007, 02:03:37 am
snakemaster
m pump
February 07, 2007, 02:03:37 am »
lift pump yes next thing on my shoping list
February 07, 2007, 09:14:57 am
m pump
February 07, 2007, 09:14:57 am »
That's a Perkins pump? Is it only available in Europe? What model? Thanks!
'86 Golf N/A Diesel -->Wife's car
February 07, 2007, 02:31:00 pm
snakemaster
m pump
February 07, 2007, 02:31:00 pm »
its a bosch pump but fitted to a perkins prina , that is fitted to a austin montego 2.0 tdi the engines are a bit soft and the cars are crap
[/img] :lol: :lol: :lol:
Reply #11
February 07, 2007, 04:24:03 pm
m pump
Reply #11 on:
February 07, 2007, 04:24:03 pm »
When it is missing, is there smoke? intake tube sucking shut?
Reply #12
February 08, 2007, 10:22:18 am
snakemaster
m pump
Reply #12 on:
February 08, 2007, 10:22:18 am »
No black smoke , but that intake and filter could be a prob i will change to a strate pipe and cone filtter
Reply #13
March 02, 2007, 03:34:11 pm
snakemaster
m pump
Reply #13 on:
March 02, 2007, 03:34:11 pm »
pic of my mtdi when the revs get to 3800 it goes down on 3 and a little smoke out of the exhaust intake ok ,i think i need a in line pump to ceep the injection pump fool
[/img]
[/img]
[/img]
Reply #14
March 02, 2007, 04:32:46 pm
snakemaster
m pump
Reply #14 on:
March 02, 2007, 04:32:46 pm »
the pump on the left hand side is of a ford escort 1.6 diesel and it has the 20mm shaft and i will change the parts out of the tdi in to the escort pump and it fits in with no mods to pulleys or bodys
[/img]
m pump
