VWDiesel Blog
Facebook Group
VWD on Twitter
Picked up a new pump...
Topic: Picked up a new pump... (Read 4831 times)
January 20, 2007, 08:11:29 pm
wolfsburgnut
January 20, 2007, 08:11:29 pm »
I just won a pump on ebay from an Iveco 49-10. It is a VE pump with an 11mm plunger. (part number 0460414003, can anyone get me some more info on it?)I want to swap the plunger into my 93 AAZ IP, can I do this, or will I need to get a pump with a 20mm main shaft as I would imagine the Iveco pump would have a 20mm main shaft.
Thanks
Peter
1995 Golf 1.9
1994 Golf Marathon
1990 Golf 1.8
1986 Golf Wolfsburg Ed.
January 21, 2007, 11:24:06 am
Tintin
January 21, 2007, 11:24:06 am »
0 460 414 003 = VE4/11F1200R94 and 17mm main shaft, and that does not give me a LDA, it's a N/A pump?
In theory, the plunger should adapt has your AAZ pump, but I am not sure, because of the width of the foot of the plunger, give news when you test.
January 21, 2007, 04:05:27 pm
wolfsburgnut
January 21, 2007, 04:05:27 pm »
In the picture, there is an LDA on it. Here is the listing just in case anyone wants to see a pic of it. Thanks Named Tintin for the info, I can't wait to start experimenting.
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=120073444022&sspagename=ADME:L:RTQ:CA:1
Thanks
Peter
1995 Golf 1.9
1994 Golf Marathon
1990 Golf 1.8
January 21, 2007, 05:04:50 pm
snakemaster
January 21, 2007, 05:04:50 pm »
Had that one in my watching but dont no the con of the head but i think it will fit the aaz pump ok, i no the one from a austin montgo will fit strait in to the aaz pump as that is what i run 11mm
Glenmorangie single highland malt
January 21, 2007, 05:08:08 pm
Tintin
January 21, 2007, 05:08:08 pm »
The 1993-1994 AAZ pump, it's a smaller plunger foot, and the 1995 and up it's a bigger foot.
January 21, 2007, 08:20:23 pm
wolfsburgnut
January 21, 2007, 08:20:23 pm »
The more I look into this, the weirder it gets. I looked up this pump in the Bosch E-cat catalog, and it doesnt have a manufacturer cross reference number. I looked up Iveco 49-10 which this pump is supposedly out of but its governed pump rpm is 1900 as compared to the 1200 listed for this pump. I emailed the seller and he says that he is positive that this pump came out of an Iveco 49-10 mini bus because he has a lot of them, and he remembers taking them out. Named Tintin do you have any thoughts on this? Do buses have a lower governed rpm than normal trucks? And if anyone wants one, he said that he has tons of them left!
Thanks
Peter
1995 Golf 1.9
1994 Golf Marathon
1990 Golf 1.8
January 21, 2007, 10:43:36 pm
Tintin
January 21, 2007, 10:43:36 pm »
Yes, i looked at has what is allotted the number of pump which you gave, it is not a iveco pump, your pump it's a modified pump, or where well it is a core of pump with the piece of iveco pump.
Your reference number is for:
http://i19.photobucket.com/albums/b166/9golf1/pieces%20pompe/pompeiveco.jpg
http://i19.photobucket.com/albums/b166/9golf1/pieces%20pompe/iveco2.jpg
And yes, the iveco 49-10 (2.5L D/TD) rev at 3600RPM:
http://i19.photobucket.com/albums/b166/9golf1/pieces%20pompe/iv4.jpg
the real reference number of électronic pump for iveco 49-10 are:
0 460 414 998
0 460 414 996
And for 49-10 mecanic
0 460 414 070
0 460 414 054 , 103, 122
0 460 424 124, 170
February 11, 2007, 09:46:51 am
wolfsburgnut
February 11, 2007, 09:46:51 am »
I just got my pump in the mail yesterday and here is the actual number on 0 460 414 008. Which I looked up and it is an Iveco 49-10 pump with 11mm plunger. It appears to have 20mm shaft, but am not sure. Will I have to get a 96-up AAZ pump with a 20mm shaft to do my swap now? Or is possible to get away with putting in a 17mm AAZ pump? Named Tintin do you have more info on the pump?
Thanks
Peter
1995 Golf 1.9
1994 Golf Marathon
1990 Golf 1.8
February 11, 2007, 10:08:15 am
Tintin
February 11, 2007, 10:08:15 am »
AAZ pump with 20mm shaft....... I ever saw, the majority of these pumps are 17mm, can be that some passat had of it, but.......
0 460 414 008 = VE4/11F1900R127, this pump has the same cam plate as the FIAT 1.9TDid, it is appreciably the same pump but with less RPM range.
February 11, 2007, 10:34:34 am
wolfsburgnut
February 11, 2007, 10:34:34 am »
I was hoping to use the pump on my 95 golf IDI that has a 93 engine in it. So Im guessing the camplate in it would be not good for an IDI. I thought I read on here that 96 and up AAZs had a 20mm shaft. But what your saying NamedTintin is that this pump as it is, with a different governor spring would make a good M-TDI pump?
Thanks
Peter
1995 Golf 1.9
1994 Golf Marathon
1990 Golf 1.8
June 19, 2019, 05:07:40 pm
Dino
User+
Re: Picked up a new pump...
June 19, 2019, 05:07:40 pm »
Hello.
The 0 460 414 008 0460414008 VE4/11F1900R127 parts list:
REPLACING PARTS:
ORDER NUMBER DESIGNATION CODE POSITION QUANTITY
2 460 283 001 SHAFT SEALING RING 2460283001 3 1
1 467 030 308 SUPPLY PUMP 1467030308 7 1
1 460 134 317 SUPPORT RING 1460134317 9 1
1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2
1 466 100 401 DRIVE SHAFT 1466100401 12 1
1 460 023 302 WOODRUFF KEY 1460023302 13 1
1 460 056 302 BUFFER 1460056302 15 2
1 466 317 301 TOOTHED GEAR 1466317301 16 1
2 460 102 001 SLIDING DISK 2460102001 17 1
1 460 232 328 ROLLER RING 1460232328 20 1
2 463 100 002 BEARING PIN 2463100002 21 4
2 460 300 005 ROLLER 2460300005 22 4
2 460 120 013 FRICTION WASHER 2460120013 23 4
1 463 103 315 ADJUSTING PIN 1463103315 24 1
1 463 120 359 RETAINING PIN 1463120359 25 1
1 461 310 300 RETAINING BRACKET 1461310300 26 1
1 460 140 334 CROSS DISK 1460140334 27 1
1 466 110 638 CAM PLATE 1466110638 29 1
2 460 223 001 SEAL RING 2460223001 30 1
2 463 104 046 TIMING-DEVICE PISTON 2463104046 31 1
1 463 218 312 SLIDING PIECE 1463218312 32 1
1 460 100 902 SELECTION GROUP SHIM RING 1460100902 33 2
1 464 619 629 COMPRESSION SPRING, 36,90 MM 1464619629 34 1
1 464 619 626 COMPRESSION SPRING, 37,10 MM 1464619626 34 1
1 464 619 623 COMPRESSION SPRING, 37,40 MM 1464619623 34 1
1 460 100 902 SELECTION GROUP SHIM RING 1460100902 35 1
2 460 223 001 SEAL RING 2460223001 36 1
1 465 530 301 CLOSING COVER 1465530301 37 1
1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2
1 461 074 312 COVER PLATE 1461074312 39 1
1 463 414 344 TORX FILLISTER SCREW 1463414344 40 2
1 468 334 596 HYDRAULIC HEAD 1468334596 50 1
2 460 210 012 O-RING 2460210012 51 1
SELECTION GROUP SHIM 52 1
1 460 105 305 GASKET 1460105305 54 4
1 466 120 305 RESTRICTION 1466120305 55 4
1 463 370 448 FITTING 1463370448 58 4
1 463 414 312 TORX FILLISTER SCREW 1463414312 60 4
1 460 210 008 O-RING 1460210008 66 1
1 467 134 128 MANIFOLD-PRESSURE COMP. 1467134128 67 1
1 463 161 592 SHAFT 1463161592 68 1
1 460 200 333 SPACER RING 1460200333 69 1
1 461 901 393 CONTROL LEVER 1461901393 72 1
1 463 315 310 FLANGE NUT 1463315310 75 1
ADJUSTING SCREW 88 1
1 461 015 302 GASKET 1461015302 92 1
1 461 907 072 FULCRUM LEVER 1461907072 95 1
2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1
1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2
1 460 105 307 GASKET 1460105307 105 2
1 464 613 611 COMPRESSION SPRING 1464613611 106 2
1 463 300 304 HEXAGON NUT 1463300304 107 1
1 460 210 313 O-RING 1460210313 109 1
1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1
SELECTION GROUP SUPPORTING DISK 111 1
1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1
1 460 100 370 SHIM RING 1460100370 114 1
1 460 422 335 SLIDING SLEEVE 1460422335 115 1
1 461 290 301 LOCKING PLATE 1461290301 116 1
1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1
1 463 123 365 RETAINING PIN 1463123365 120 1
1 464 650 370 EXTENSION SPRING 1464650370 122 1
2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4
1 460 210 349 O-RING 1460210349 129 1
1 463 461 306 SCREW PLUG 1463461306 130 1
1 460 105 306 FLAT SEAL RING 1460105306 131 1
1 463 453 306 BLEEDER SCREW 1463453306 132 1
1 460 225 081 O-RING 1460225081 133 1
1 460 225 082 O-RING 1460225082 134 1
1 460 362 309 CONTROL VALVE 1460362309 135 1
1 463 456 303 HOLLOW BOLT 1463456303 136 1
1 460 591 315 PROTECTIVE CAP 1460591315 140 1
2 410 508 006 PROTECTIVE CAP 2410508006 141 1
1 410 407 004 PROTECTION SLEEVE 1410407004 142 1
1 460 500 307 SPRING SEAT 1460500307 203 1
1 900 508 202 PROTECTIVE CAP 1900508202 209 1
1 464 611 318 COMPRESSION SPRING 1464611318 215 1
1 464 651 461 COILED SPRING 1464651461 220 1
0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1
1 461 900 503 CONTROL LEVER 0330001040 289 1
1 463 433 310 WASHER-AND-SCREW ASSEMBLY 1463433310 292 1
1 460 522 328 SPRING SEAT 1460522328 325 1
1 460 522 304 SPRING SEAT 1460522304 329 1
1 463 386 301 VENT FITTING 1463386301 336 1
1 460 558 303 PROTECTIVE CAP 1460558303 339 1
1 465 130 890 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465130890 800 1
1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1
1 463 590 901 ASSEMBLY OF SERVICE PARTS GOVERNOR SHAFT Explanations 1463590901 13 1
The same camplate as on 0 460 414 059 from Croma. Now I think the catalogue I found is good.
0 460 414 054 0460414054 VE4/11F1900R294
REPLACING PARTS:
1 467 030 310 SUPPLY PUMP 1467030310 7 1
1 466 110 604 CAM PLATE 1466110604 29 1
1 463 104 390 TIMING-DEVICE PISTON 1463104390 31 1
1 464 619 767 COMPRESSION SPRING 1464619767 34 1
1 464 619 632 COMPRESSION SPRING, 43,00 MM 1464619632 34 1
2 464 619 001 COMPRESSION SPRING, 44,00 MM 2464619001 34 1
1 468 334 603 HYDRAULIC HEAD 1468334603 50 1
1 463 370 610 CONSTANT-PRESSURE VALVE 1463370610 58 4
1 463 414 361 MICROENCAPSULATED SCREW 1463414361 60 4
1 467 134 595 MANIFOLD-PRESSURE COMP. 1467134595 67 1
1 463 161 872 SHAFT 1463161872 68 1
1 461 907 144 FULCRUM LEVER 1461907144 95 1
1 460 422 363 SLIDING SLEEVE 1460422363 115 1
1 460 508 309 SEALING CAP 1460508309 116 1
1 464 650 364 EXTENSION SPRING 1464650364 122 1
2 464 633 002 COMPRESSION SPRING 2464633002 200 1
F 002 D11 858 PROTECTIVE CAP F002D11858 209 1
1 464 611 308 COMPRESSION SPRING 1464611308 215 1
1 464 651 458 COILED SPRING 1464651458 220 1
1 461 900 503 CONTROL LEVER 1461900503 289 1
1 460 505 308 CLOSURE CAP 1460505308 471 1
1 460 591 313 SEALING CAP, RED 1460591313 808 1
2 420 580 005 SEALING CAP, RED 2420580005 809 1
1 463 590 901 ASSEMBLY OF SERVICE PARTS GOVERNOR SHAFT 1463590901 813 1
0 469 414 070 0460414070 VE4/11F1900R350
REPLACING PARTS:
1 460 232 327 ROLLER RING 1460232327 20 1
1 463 104 422 TIMING-DEVICE PISTON 1463104422 31 1
1 468 334 601 HYDRAULIC HEAD 1468334601 50 1
1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2
1 467 134 257 MANIFOLD-PRESSURE COMP. 1467134257 67 1
1 463 163 188 PART LOAD GOVERNOR 1463163188 68 1
1 200 101 640 SHIM 1200101640 69 1
1 461 900 558 CONTROL LEVER 1461900558 72 1
1 461 907 156 FULCRUM LEVER 1461907156 95 1
1 460 422 375 SLIDING SLEEVE 1460422375 115 1
1 460 101 376 GASKET 1460101376 189 1
1 467 230 350 CONTROL UNIT 1467230350 235 1
1 463 414 305 TORX FILLISTER SCREW 1463414305 237 1
2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2
2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 275 1
2 910 142 195 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x14-8.8 2910142195 276 2
2 460 223 001 SEAL RING 2460223001 277 1
1 461 900 508 CONTROL LEVER 1461900508 289 1
1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 292 1
1 463 218 303 INTERMEDIATE PIECE 1463218303 294 1
1 460 342 311 INTERMEDIATE PIECE 1460342311 295 1
1 463 412 301 CHEESE HEAD SCREW 1463412301 296 1
1 463 305 305 CLAMPING PIECE 1463305305 297 1
1 460 101 620 SHIM 1460101620 380 1
1 465 530 857 FITTING COVER 1465530857 381 1
1 461 933 388 CONTROL LEVER 1461933388 382 1
1 461 933 386 CONTROL LEVER 1461933386 382 1
1 461 331 331 STOP BRACKET 1461331331 383 1
1 464 651 433 COILED SPRING 1464651433 384 1
2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 385 1
2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 386 1
1 464 736 300 CLAMPING BAND 1464736300 400 1
1 463 212 300 RUBBER PLUG 1463212300 401 1
1 461 016 315 STOP PLATE 1461016315 403 1
1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 406 1
2 916 699 131 SPRING LOCK WASHER, DIN 128 - A5-FSt 2916699131 407 1
1 460 326 387 DRIVER 1460326387 408 1
1 461 334 339 BRACKET 1461334339 409 1
1 463 300 319 HEXAGON NUT 1463300319 410 1
2 916 012 011 PLAIN WASHER, DIN 433 - 5,3-160 HV 2916012011 427 1
1 467 217 354 POTENTIOMETER 1467217354 442 1
1 461 098 344 FASTENING PLATE 1461098344 443 1
1 463 433 320 WASHER-AND-SCREW ASSEMBLY 1463433320 444 3
2 912 702 197 CHEESE HEAD SCREW 2912702197 472 2
1 465 130 898 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465130898 800 1
Last Edit: June 21, 2019, 01:21:08 pm by Dino
Reply #11
June 21, 2019, 01:29:19 pm
Dino
User+
Reply #11 on:
June 21, 2019, 01:29:19 pm »
Hello.
0 460 414 103 0460414103 VE4/11F1900R522
REPLACING PARTS:
1 463 103 316 ADJUSTING PIN 1463103316 24 1
2 466 110 015 CAM PLATE 2466110015 29 1
1 463 104 624 TIMING-DEVICE PISTON 1463104624 31 1
1 460 144 302 SHIM RING 1460144302 33 1
1 464 618 934 COMPRESSION SPRING 1464618934 34 1
1 460 100 178 PLAIN WASHER 1460100178 35 1
1 465 530 901 CLOSING COVER 1465530901 37 1
1 461 074 330 COVER PLATE 1461074330 39 1
2 463 414 001 TORX FILLISTER SCREW 2463414001 40 2
1 468 334 617 HYDRAULIC HEAD 1468334617 50 1
1 463 370 614 CONSTANT-PRESSURE VALVE 1463370614 58 4
1 463 414 312 TORX FILLISTER SCREW 1463414312 60 3
1 467 134 508 MANIFOLD-PRESSURE COMP. 1467134508 67 1
1 463 163 157 PART LOAD GOVERNOR 1463163157 68 1
1 461 907 162 FULCRUM LEVER 1461907162 95 1
1 460 362 469 CONTROL VALVE 1460362469 135 1
1 463 456 344 HOLLOW BOLT 1463456344 136 1
1 467 230 386 CONTROL UNIT 1467230386 235 1
0 330 001 042 PUSHING ELECTROMAGNET 0330001042 240 1
SELECTION GROUP SHIM 452 3
1 464 616 998 COMPRESSION SPRING 1464616998 453 1
1 463 219 304 CONTROL SPOOL 1463219304 455 1
0 460 414 122 0460414122 VE4/11F1900R522-2
REPLACING PARTS:
1 466 110 640 CAM PLATE 1466110640 29 1
1 468 334 798 HYDRAULIC HEAD 1468334798 50 1
1 463 370 616 CONSTANT-PRESSURE VALVE 1463370616 58 4
1 467 134 623 MANIFOLD-PRESSURE COMP. 1467134623 67 1
1 461 905 427 FULCRUM LEVER 1461905427 95 1
1 464 616 956 COMPRESSION SPRING 1464616956 453 1
0 460 424 124 0460424124 VE4/12F1800R657
REPLACING PARTS:
1 469 990 730 ADJUSTING PIN 1469990730 24 1
1 466 110 643 CAM PLATE 1466110643 29 1
1 463 104 748 TIMING-DEVICE PISTON 1463104748 31 1
1 469 990 732 SLIDING PIECE 1469990732 32 1
1 464 619 868 COMPRESSION SPRING 1464619868 34 1
1 468 374 041 HYDRAULIC HEAD 1468374041 50 1
2 463 370 021 FITTING 2463370021 58 4
1 467 135 003 MANIFOLD-PRESSURE COMP. 1467135003 67 1
1 463 161 596 SHAFT 1463161596 68 1
1 461 907 206 FULCRUM LEVER 1461907206 95 1
1 461 905 441 FULCRUM LEVER 1461905441 95 1
1 463 590 311 GOVERNOR SHAFT 1463590311 108 1
1 460 422 324 SLIDING SLEEVE 1460422324 115 1
1 464 650 402 EXTENSION SPRING 1464650402 122 1
1 460 362 476 CONTROL VALVE 1460362476 135 1
1 464 611 451 COMPRESSION SPRING 1464611451 215 1
1 464 651 457 COILED SPRING 1464651457 220 1
1 467 230 421 CONTROL UNIT 1467230421 235 1
1 460 491 300 GUIDE SLEEVE 1460491300 294 1
1 460 410 310 SPRING SLEEVE 1460410310 295 1
2 912 742 154 CHEESE HEAD SCREW 2912742154 296 1
1 463 305 308 CLAMPING PIECE 1463305308 297 1
1 461 933 426 CONTROL LEVER 1461933426 382 1
1 461 933 425 CONTROL LEVER 1461933425 382 1
1 460 210 322 O-RING 1460210322 392 1
1 463 414 306 LOCKING SCREW 1463414306 393 1
1 461 331 364 INTERMEDIATE PLATE 1461331364 394 1
1 465 134 922 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465134922 800 1
Last Edit: June 21, 2019, 01:44:29 pm by Dino
Reply #12
June 21, 2019, 01:38:55 pm
Dino
User+
Reply #12 on:
June 21, 2019, 01:38:55 pm »
0 460 424 170 0460424170 VE4/12F1800R657-1
REPLACING PARTS:
0 281 005 046 SOLENOID-VALVE CONTROL UN 0281005046 184 1
1 467 010 491 PARTS SET RETAINING PIN 1467010491 806 1
1 467 010 555 PARTS SET THEFT PROTECTION 1467010555 825 1
Electronic pumps:
0 460 414 996 0460414996 VE4/11E1900R565
REPLACING PARTS:
2 466 100 028 DRIVE SHAFT 2466100028 12 1
2 460 232 030 ROLLER RING 2460232030 20 1
2 463 103 004 ADJUSTING PIN 2463103004 24 1
2 461 310 001 RETAINING BRACKET 2461310001 26 1
2 466 110 020 CAM PLATE 2466110020 29 1
2 463 104 041 TIMING-DEVICE PISTON 2463104041 31 1
1 464 619 938 COMPRESSION SPRING 1464619938 34 1
1 465 530 903 CLOSING COVER 1465530903 37 1
2 468 334 009 HYDRAULIC HEAD 2468334009 50 1
2 463 370 010 CONSTANT-PRESSURE VALVE 2463370010 58 4
2 467 135 202 POSITIONER 2467135202 67 1
2 460 209 001 SEAL RING 2460209001 68 1
1 460 206 305 GASKET 1460206305 92 1
2 463 452 003 HEXAGON SCREW 2463452003 104 1
1 460 105 307 GASKET 1460105307 105 1
2 912 712 205 CHEESE HEAD SCREW 2912712205 123 3
2 463 433 001 WASHER-AND-SCREW ASSEMBLY 2463433001 123 3
2 916 022 012 PLAIN WASHER 2916022012 124 4
2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 124 4
2 463 440 005 WASHER-AND-SCREW ASSEMBLY 2463440005 125 1
2 463 440 002 HEXAGON SCREW 2463440002 125 1
1 460 362 378 CONTROL VALVE 1460362378 135 1
2 467 413 025 OVERFLOW VALVE 2467413025 136 1
1 460 105 312 FLAT SEAL RING 1460105312 137 1
2 463 317 004 CAP NUT 2463317004 138 1
2 461 332 025 BRACKET 2461332025 395 1
1 463 433 321 WASHER-AND-SCREW ASSEMBLY 1463433321 396 1
2 461 300 002 CLAMP 2461300002 397 1
0 281 002 127 SOLENOID-OPERATED VALVE 0281002127 424 1
1 463 414 344 TORX FILLISTER SCREW 1463414344 425 2
2 465 130 923 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 2465130923 800 1
0 460 414 998 0460414998 VE4/11E1900R480
REPLACING PARTS:
2 467 135 128 POSITIONER 2467135128 67 1
2 912 712 203 TORX FILLISTER SCREW 2912712203 123 3
2 467 413 009 OVERFLOW VALVE 2467413009 136 1
2 461 332 007 BRACKET 2461332007 395 1
