S-PAutomotive.com
Author Topic: HELP Need a TDi-M Injection Pump  (Read 5705 times)
December 20, 2006, 02:53:59 pm
VDub_Fun
  • 69
« on: December 20, 2006, 02:53:59 pm »
I need a TDi-M injection Pump. I got a complete TDi-M swap only to put the motor in the car and find out that the Injection Pump is toast. If anyone has a mechanical TDi pump Please let me know I am in desperiate need of one.
Contact me via PM,  E-Mail: [email protected], or E-Mail: [email protected]
Reply #1December 20, 2006, 11:53:55 pm
« Reply #1 on: December 20, 2006, 11:53:55 pm »
how toast is it? can't you just buy a rebuild kit for it? maybe you just need a new feed pump and new rotor.
is the pump sucking any fuel?  maybe theres too much air in it.
Reply #2December 21, 2006, 05:48:01 pm
VDub_Fun
  • 69
« Reply #2 on: December 21, 2006, 05:48:01 pm »
Pump is totally toast. Pump is full of diesel on the low pressure side, nothing on the high pressure side. Pump will not suck fuel from low to high, or from the tank for that matter. Yes I did crank the engine, killed off 2 batteries and one starter. I have primmed the pump many times. Pump was completely dry when I obtained it. If there is some trick that I am missing about priming up the pump please let me know.
Thanks
Reply #3December 21, 2006, 06:11:39 pm
Turbinepowered
  • 1206
« Reply #3 on: December 21, 2006, 06:11:39 pm »
Crack the injection lines to bleed air pressure? I've heard that sometimes the air in the injection lines can be pressurized enough by the pump to prevent proper priming. Loosening the lines at the injector then turning it over should prevent that.
Reply #4December 21, 2006, 06:28:24 pm
VDub_Fun
  • 69
« Reply #4 on: December 21, 2006, 06:28:24 pm »
Tryed that several times, nothing, not a drip of diesel from the high pressure side.
Reply #5December 21, 2006, 07:05:01 pm
vwmike
  • 1158
« Reply #5 on: December 21, 2006, 07:05:01 pm »
Usually I use a little fuel pump (the electric kind for carburetors) to push the fuel through the pump. When I get volume out of the return line I reconnect the feed and it usually fires right up.
Reply #6December 21, 2006, 07:42:33 pm
VDub_Fun
  • 69
« Reply #6 on: December 21, 2006, 07:42:33 pm »
I havent tryed that one yet. Well if I can find a little in line pump, I think Ill give it a go, if that doesnt get fuel to the high pressure side, then I think nothing will
Reply #7December 21, 2006, 09:16:40 pm
« Reply #7 on: December 21, 2006, 09:16:40 pm »
unless you stick a vacuum pump on the diesel return hose to get fuel flowing out of the pump, your car probably will not fire.  i've had a return hose go on me, and just by changing it for a brand new hose, that little bit of air made the car take about a full minute of cranking just to start up! :shock:
me and andy2 did a ghetto pump bleed  :lol: ... he slowly fed the pump fuel (10w30... :lol:) while i cranked it over (he fed the pump directly).  i can honestly say that the pump took a LOT of fuel... man that vacuum pump would have saved about 20-30 minutes!!!  If you take off the main line going to the pump and pour diesel in it, and you crank it over, does the fuel get sucked into the pump? if so its dry.  (remember to have the injectors cracked at this point)
I still think that your pump still has air in it, unless you've actually bled it with a vacuum pump.  the car should still at least run half assed with a bad pump.
Reply #8December 21, 2006, 10:32:16 pm
Turbinepowered
  • 1206
« Reply #8 on: December 21, 2006, 10:32:16 pm »
Just a wild thought... but is the fuel shutoff solenoid working properly?
Reply #9December 22, 2006, 12:25:23 pm
VDub_Fun
  • 69
« Reply #9 on: December 22, 2006, 12:25:23 pm »
Yup shut off seloid is working , hear a click when the key is turned to accessory, and when trying to start.
Reply #10December 22, 2006, 12:33:39 pm
VDub_Fun
  • 69
« Reply #10 on: December 22, 2006, 12:33:39 pm »
I filled up the pump directly from the feed. Filled it up untill diesel spilled a little bit, conntected the feed hose to filter, filled the feed hose to the pump, cranked engine. Nothing no movement of fuel. Removed the line, pump is still full, no movement of fuel what so ever, no air bubbles in feed line. Injectors were left with the lines off, no fule in lines.
Reply #11December 22, 2006, 04:38:19 pm
andy2
« Reply #11 on: December 22, 2006, 04:38:19 pm »
If your inj pump is no good then you should take it to a fuel shop where it could be looked at. It could just have stuck transfer pump blades from sitting for a while with old gummed up fuel.It may just need to come apart to be cleaned then reasembled and tested for less $$$$ than a new pump if no major internal parts are required :wink:.
Reply #12December 23, 2006, 12:07:42 am
VDub_Fun
  • 69
« Reply #12 on: December 23, 2006, 12:07:42 am »
The reason I ask about the movement of the plunger is that you could have a broken plunger.  If the plunger is moving, then you can assume that the high pressure side is okay.  I have heard of stop solenoids still clicking and yet not allowing fuel to pass.  Really can't see how that could be the case, but might be worth removing the solenoid plunger altogether just to eliminate it as a possibility.  You can always dump the clutch to shut it off if you do get it running.  Often times if a pump is stored dry, the vanes of the vane pump will stick.  It is only centrifugal motion (and gravity to a slight extent) that keeps the vanes against the sides of the pump housing.  If the vanes stick, then the low pressure pump will not function at all.
Andrew
I think that the vanes are stuck personally, or the plunger is broken as you have said. Ive primed up alot of diesel pumps in the past and never had this issue before.
As for taking it to a shop to have is dissasembled and cleaned/inspected no one around my immediate area has any clue on mechanical TDI pumps, let alone the electronic ones (Myself included. I only have a very very ruff idea of what is what , and what does what). The 2 shops that are semi local to me dont even have the equipment to test the TDi electronic pumps. I have been in contact with Kelch Repair Services in Ohio, and they are going to build me a Mechanical TDi pump. I have already sent down a electronic TDi pump, just waiting for it to get there so they can build the pump. Hopefully all goes well, and I get a correctly working mechincal TDi pump.
Reply #13December 23, 2006, 06:07:03 am
« Reply #13 on: December 23, 2006, 06:07:03 am »
isn't the mechanical tdi pump just a modded 1.6 with a tdi cam plate, bigger head, and some other parts??? correct me if i am wrong...  if thats so then pretty much any diesel shop should be able to crack open the pump and play around with it :)
Reply #14December 23, 2006, 10:22:42 am
VDub_Fun
  • 69
« Reply #14 on: December 23, 2006, 10:22:42 am »
When I phone the semi local shops up and explained to them that it was basically a modded 1.6L Injection pump they said not to even bring it.
Fixmyvw.com
