Author Topic: What oil do you use?  (Read 9644 times)
December 08, 2006, 08:14:43 pm
wolfsburgnut
  • 126
« on: December 08, 2006, 08:14:43 pm »
I was using Valvoline oil (15W-40 CI-4 rated I think) up until a couple of months ago until my local altrom dealer convinced me to try Liqui-Moly High Tech Touring 15W-40.  Its got the VW rating 502 I think, and I immediately noticed a huge difference in startup oil pressure (for the better) and oil consumption (about a liter every 6000 kms).  However I noticed the API rating on it is only for CF!!!  What the heck?  I got some Liqui-Moly MoS2 10w40 semi synthetic for my car today, and again noticed it was only rated for CF.
I was wondering what kinds of oil other people use in their cars and if anybody has experience with the Liqui-Moly.  I highly recommend it, even though its 26 bucks for 5 L of the High Tech and 36 bucks for 5L of the MoS2! :shock:
Peter
1995 Golf 1.9
1994 Golf Marathon
1990 Golf 1.8
1986 Golf Wolfsburg Ed.
Reply #1December 09, 2006, 05:34:21 am
« Reply #1 on: December 09, 2006, 05:34:21 am »
isn't CF rated for turbo diesels???
the original rating for 1.6TD's was CD wasn't it?
Reply #2December 09, 2006, 08:46:42 am
SMOKEYDUB
  • 630
« Reply #2 on: December 09, 2006, 08:46:42 am »
i never had any problems with that oil. we even use it at work  :)
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #3December 09, 2006, 10:19:25 am
g-spec
  • 289
« Reply #3 on: December 09, 2006, 10:19:25 am »
I use liqui moly on my corrado...havent got the diesel running yet but will be using it aswell....i like the oil....
first when i changed to it in the corrado i noticed it ran smoother and quieter!! it could have only been the new oil....but i have had no problems with it!!!!
Reply #4December 09, 2006, 12:36:24 pm
« Reply #4 on: December 09, 2006, 12:36:24 pm »
5w 40 shell rotella t full synthetic
Reply #5December 09, 2006, 02:15:05 pm
Black Smokin' Diesel
  • 656
« Reply #5 on: December 09, 2006, 02:15:05 pm »
Tech2000 full synthetic 10w30 (wal-mart oil). 20$ for 4.4L. Very happy with cold starts so far :D
Reply #6December 09, 2006, 06:06:31 pm
sethyboy85
  • 284
« Reply #6 on: December 09, 2006, 06:06:31 pm »
I am trying a blend this go around, 0w-40 Mobil 1 and Walmart 15w-40 about a 50/50... seems fine
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #7December 09, 2006, 07:24:50 pm
« Reply #7 on: December 09, 2006, 07:24:50 pm »
Quote from: "Trev0rbr"
Pretty much what I run, 0W40 shell rotella T SB full synthetic. Great stuff, no complaints so far
Reply #8December 09, 2006, 11:03:08 pm
ricosuave
  • 244
« Reply #8 on: December 09, 2006, 11:03:08 pm »
ufa polar plus 0w30 (rebranded esso xd3 synthetic) for ~22 a 5L jug
Reply #9December 10, 2006, 05:43:33 am
jimbrown618
  • 43
« Reply #9 on: December 10, 2006, 05:43:33 am »
Quote from: burn_your_money
Quote from: Trev0rbr
Same here....runs great
Reply #10December 10, 2006, 06:22:11 am
« Reply #10 on: December 10, 2006, 06:22:11 am »
i notice a difference in how it runs with the sythetic seems looser, the turbo seems to like it too
Reply #11December 10, 2006, 06:35:44 am
anarchyx34
« Reply #11 on: December 10, 2006, 06:35:44 am »
I was using Rotella 15w-40 for a while, but I noticed my oil consumption was pretty bad (1 qt 500 miles approx). I tried Delo 400 15w-40 and now it's a lot better, down to 1/2 qt every 1200 miles. Cold starts seem to be ok.
Reply #12December 10, 2006, 07:50:55 am
oil
« Reply #12 on: December 10, 2006, 07:50:55 am »
I run the Rotella synthetic also. I know synthetic is better for the turbo
because synthetic takes heat a lot better, and is less likely to coke up. I
used to run it in my circle track car when I raced. Had one hot day where my
 water temp was a continuous 260 or above, as the gauge only went that
high. We were sure the cylinders and pistons were going to be scored, but
they only had polished marks on them. That's when I lost all doubt that
synthetic was way better.
Reply #13December 10, 2006, 08:29:46 am
Staley
  • 96
    • http://www.bartuning.com
« Reply #13 on: December 10, 2006, 08:29:46 am »
I use Amsoil Series 3000 Synthetic 5W-30 Heavy-Duty Diesel Oil (HDD)
Here are the ratings
• API CI-4+, CF, CF-2, SL • ACEA A3/B3, E2, E3, E5 • Global DHD-1 • JASO DH-1 • Mack EO-N Premium Plus ’03 • DDC Power Guard 93K214 • Caterpillar ECF-1 • Cummins CES 20071, 20072, 20076, 20077, 20078 • Volvo VDS-2, VDS-3 • MB 228.1, 228.3, 229.1 • MAN 3275 • MTU Type 1 • MIL-PRF-2104G
Houston's APR Distributor
www.bartuning.com
Reply #14December 10, 2006, 08:43:45 am
Dennis Froelich
  • 258
« Reply #14 on: December 10, 2006, 08:43:45 am »
I did use Delo 400 15w40, but went to Rotella T 15w40. I'm hesitant to use synthetic oil since it has had dino oil in it forever.
Any responses about me hesitant about changing over to synthetic appreciated. :D
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
