Author Topic: Glow Plug Problems  (Read 6243 times)
Reply #15November 25, 2006, 07:07:28 am
addautomotive
Glow Plug Problems
« Reply #15 on: November 25, 2006, 07:07:28 am »
Hot Damn!
Quote from: "BellCityDubber"
Quote from: "libbybapa"
Quote from: "addautomotive"
whazzupwitdat?
Must be a glitch within the settings of this particular forum... It works fine on other php-based forums I use.
I'm going to call my MLA, my Pastor and the UN to complain.
I find if I click on "disable HTML in this post" that the quote function works great
Well, I'll be jiggered...
Actually you can set that as a default in your profile:
Always allow HTML: (check "no")
Andrew
yep
works like a charm :D
Reply #16November 26, 2006, 02:02:31 pm
BellCityDubber
  • 251
Glow Plug Problems
« Reply #16 on: November 26, 2006, 02:02:31 pm »
Just to follow up (becasue everyone likes a conclusion to a story)
I went out and got a few 8mm nuts and a 8mm gear wrench. I managed to use a few tips from people to get the last few 8mm nuts on the busbar..
8mm gear wrench with the nut inside with a dab of grease to hold the nut while a screwdriver pushed on for tension seemed to work just nicely.
Reply #17November 26, 2006, 02:47:48 pm
Glow Plug Problems
« Reply #17 on: November 26, 2006, 02:47:48 pm »
Thanks for the follow up. It's always nice to know what works
Reply #18January 23, 2007, 12:21:11 pm
be12clicks
Glow Plug Problems
« Reply #18 on: January 23, 2007, 12:21:11 pm »
Just wanted to say this thread was a huge help for my job of changing my glow plugs out on a 1990 Turbo Diesel Jetta I have.  Screwdriver and grease saved the day.  Thanks!
BTW, new member here, glad to have come across this site, I've had my car for close to 6 months now and am loving driving diesel.
Reply #19February 02, 2007, 05:09:49 pm
theocrytus
  • 8
Glow Plug Problems
« Reply #19 on: February 02, 2007, 05:09:49 pm »
if you wanna use individual wires between the glow plugs use a 14 or maybee even a 12 gauge wire. attach one of those round connectors to both ends of the wire so you can tighten it to the post of glow plug. So it look like something below. This is what I have done after I F'd my bus bar up. The VW dealership wanted $50 for a new one so this is what i did and i have had no problems at all.
0=---------=0=---------=0=--------=0
