Author Topic: Glow Plug Problems  (Read 6238 times)
November 22, 2006, 12:51:30 pm
BellCityDubber
  • 251
Glow Plug Problems
« on: November 22, 2006, 12:51:30 pm »
Ok, so I decided to do my glow plugs on my own today.
I managed to get the ones on the tranny side out and replaced.
The ones behind the pump aren't that far along.
I think I may have messed up...
the one closest to the belt side isnt going in with ease, I think I may have messed the threads...  :cry: the DIY said hand tighten, but I cant get my paws in there.  :(
and the one right behind the pump is halfway in, halfway out and isnt going ANYWHERE... :shock:
I dunno what I'm going to do, does anyone have any advise they could give me? (please be reasonable)
thanks guys.
Reply #1November 22, 2006, 12:57:49 pm
Baxter
Glow Plug Problems
« Reply #1 on: November 22, 2006, 12:57:49 pm »
Take the pump off to get a better view if you really do think you've f**ked something.
Ohterwise, bite the bullet and take it to a man that can.
Reply #2November 22, 2006, 07:13:17 pm
BellCityDubber
  • 251
Glow Plug Problems
« Reply #2 on: November 22, 2006, 07:13:17 pm »
Well, everythings in and back together
took it for a boot.. hammered the smoke button up till 15psi a number of times....
checked the one glow plug that I thought would be suspect.
No leaks, nothing.
I would assume I'm okay.
Reply #3November 22, 2006, 08:43:10 pm
Glow Plug Problems
« Reply #3 on: November 22, 2006, 08:43:10 pm »
How'd you fix it? what was wrong?
Reply #4November 23, 2006, 12:12:26 am
BellCityDubber
  • 251
Glow Plug Problems
« Reply #4 on: November 23, 2006, 12:12:26 am »
Quote from: "burn_your_money"
I dunno, it was just really hard to thread in, so I took it out, and tried threading it in again, and... well.. same result.. it was in straight like the rest of them, but required a bit more effort than the other three.
I went on a few sites after querying "glow plugs" in google and triend a recommendation used on a MB forum.  Use WD40 on the threads while threading in.
I also checked the threads and there was grey stuff (not metal shards) in the threads of the plug. [maybe anti-sieze?]
so I threaded it back in... took it for a run or two or three and I was good.
if I did manage to F it up, I think I'll just see how it goes for a while, if it leaks. oh well.. time for a new head... but I'm toying with the idea of getting a 1.9 head anyways..
well, we'll see
Reply #5November 23, 2006, 06:11:32 am
Glow Plug Problems
« Reply #5 on: November 23, 2006, 06:11:32 am »
Oh ok, so there was probably some oil residue making it tough to turn in (hopefully anyways)
Reply #6November 23, 2006, 11:08:24 am
BellCityDubber
  • 251
Glow Plug Problems
« Reply #6 on: November 23, 2006, 11:08:24 am »
yea, I would guess so.. but now I cant get the last 2 8mm nuts on the glow plugs behind the injection pump..
meh
but the car runs anyways :D
Reply #7November 23, 2006, 11:33:52 am
addautomotive
Glow Plug Problems
« Reply #7 on: November 23, 2006, 11:33:52 am »
Try putting a little grease on the wrench to get the nut to stick to it.
I've started doing it this way:
-put grease on a flat head screwdriver
-stick the nut to the side of the screwdriver
-using the screwdriver, place the nut against the thread of the glowplug
-use a second flat screwdriver to "spin" the nut on, pushing against the flats on the nut
-once the nut's on, tighten with 8mm wrench
Reply #8November 23, 2006, 11:37:30 am
addautomotive
Glow Plug Problems
« Reply #8 on: November 23, 2006, 11:37:30 am »
'nother trick:
Instead of the "bus" bar that connects all the glow plugs, run an individual wire to each GP. That way, if you start having trouble you can easily check each one individually.
Reply #9November 23, 2006, 11:44:02 am
1slowvw
Glow Plug Problems
« Reply #9 on: November 23, 2006, 11:44:02 am »
Quote from: addautomotive
'nother trick:
I have thought of doing this, would you mind letting me know what guage wire your using. My "bus" bar has seen better days and I would like this car to start when the cold weather sets In.
                                                      1SlowVW
Reply #10November 23, 2006, 05:53:51 pm
Glow Plug Problems
« Reply #10 on: November 23, 2006, 05:53:51 pm »
Another idea is to connect all the glow plugs to the bus bar when they are not installed. Keep the 8mms loose. You can still wrench on the injector, and then you just need to tighten the 8mms after. I've never done it this way before so I don't know how well it works. I've only changed plugs once and I had the pump off
Reply #11November 24, 2006, 05:46:12 am
addautomotive
Glow Plug Problems
« Reply #11 on: November 24, 2006, 05:46:12 am »
Quote from: burn_your_money
Yeah I read about that method too. I tried it once, but not successfully. As I tightened the glow plugs, the 8mm nuts would loosen against the bus bar. That's when I said "F this" and started running individual wires. Maybe others have done that succesfully though. Overall, I think it's a practice thing. I've done it 4-5 times now; first time I did glow plugs it took me over half a day, last time it took me 30-40 minutes.
Quote from: 1SlowVW
Not sure, actually. I got a roll of really nice thick copper wire at a yard sale. I'd say it's 8 or 10ga. Used good quality stainless connections. Woulda used copper if it was available, but was in a pinch.
I wish the quote function was working better
Reply #12November 24, 2006, 08:25:58 am
addautomotive
Glow Plug Problems
« Reply #12 on: November 24, 2006, 08:25:58 am »
whazzupwitdat?
Must be a glitch within the settings of this particular forum... It works fine on other php-based forums I use.
I'm going to call my MLA, my Pastor and the UN to complain.
Reply #13November 24, 2006, 12:00:55 pm
BellCityDubber
  • 251
Glow Plug Problems
« Reply #13 on: November 24, 2006, 12:00:55 pm »
Quote from: "addautomotive"
whazzupwitdat?
I find if I click on "disable HTML in this post" that the quote function works great
Reply #14November 25, 2006, 12:36:19 am
BellCityDubber
  • 251
Glow Plug Problems
« Reply #14 on: November 25, 2006, 12:36:19 am »
Quote from: "libbybapa"
Quote from: "BellCityDubber"
whazzupwitdat?
Well, I'll be jiggered...
Actually you can set that as a default in your profile:
Always allow HTML: (check "no")
Andrew
yep
works like a charm :D
