Author Topic: what turbo for 1.6 td with 10mm pump?  (Read 7796 times)
November 18, 2006, 03:58:41 am
zaprzal
  • 160
    • turbodiesel.pl
« on: November 18, 2006, 03:58:41 am »
I've got k24 from 1.6 td in garage, what max boost can I run with this turbo on 1.6 td, ported head, 10mm pump,1.9 metal hg, egt gauge, ic, bigger downpipe and freeflow exhaust? Is that turbo good enough or should I look for different one?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #1November 18, 2006, 04:25:21 am
Benjamin
  • 485
« Reply #1 on: November 18, 2006, 04:25:21 am »
it all depend how much power you wanna make.
the k24 will give on max boost something like 140hp, if you realy go to the max it should give max150hp.
Do you got pics from the porting?
Greetz, Benjamin
Must make +250hp
Reply #2November 18, 2006, 06:10:01 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #2 on: November 18, 2006, 06:10:01 am »
as much as I can get from this setup for DAILY USE car
but how much boost can I run with k24?
porting and putting metal hg will start on monday, next week.
Is it true that garrett t3 would be better than k24?
Reply #3November 18, 2006, 04:14:05 pm
Benjamin
  • 485
« Reply #3 on: November 18, 2006, 04:14:05 pm »
Read the forum  :wink:  the con rods should braek at 400Nm
i think you can get something like 170hp or more out of that 10mm.
some say, i dont think its so much difrence, anyway, if you want the max for daily use, i think you can even get a bigger turbo.
i personaly like VNT turbo's, other guys like turbo's like Holset, but i cant say wich is the best.
About your port-job, can you add some fotos on the forum?
i think something like 25psi, maybe 30psi, can someone confirm?????????
Greetz, Benjamin
Must make +250hp
Reply #4November 18, 2006, 05:13:17 pm
« Reply #4 on: November 18, 2006, 05:13:17 pm »
there effeciency runs out before 25 pounds,  but it's not like you can't run them any higher than that, blake has ran his to almost 40 psi.  it's really all about how big your balls are and how much you have to lose, if you can't afford to replace it or have it break, then i wouldn't go above 25psi
Reply #5November 19, 2006, 01:45:19 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #5 on: November 19, 2006, 01:45:19 am »
thanks for help, I'll start with 25psi and think about something bigger next year
If I could get 130-140hp (at the beginning of course ;) ) I would be very, very happy  :D I've got 95 crank hp at the moment with stock pump, stock downpipe, and garrett T2 at 17psi (fueling not matched to boost)
If I only get photos I'll post them but I don't promise that I'll get them
Read the forum
I read it a lot  :wink:
Reply #6December 01, 2006, 08:20:41 am
HP
  • 225
« Reply #6 on: December 01, 2006, 08:20:41 am »
So, you keep us updated with that project of yours.  :)  With photos whenever possible!
Reply #7December 02, 2006, 03:53:10 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #7 on: December 02, 2006, 03:53:10 am »
Only photo I have is 2,20" downpipe before welding:
Reply #8December 05, 2006, 01:16:02 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #8 on: December 05, 2006, 01:16:02 am »
some more photos:
Reply #9December 05, 2006, 03:39:14 am
« Reply #9 on: December 05, 2006, 03:39:14 am »
What is with the flat area opposite the piston releifs?
My pistons don't look like that.
Reply #10December 05, 2006, 04:11:22 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #10 on: December 05, 2006, 04:11:22 am »
How does your pistons looks like?
Reply #11December 05, 2006, 04:43:48 am
Audi80
« Reply #11 on: December 05, 2006, 04:43:48 am »
My pistons look same too.
Reply #12December 07, 2006, 04:49:49 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #12 on: December 07, 2006, 04:49:49 am »
k24 works  :) I can hit 30psi with stock pump.
