Pump Mods/Gov Mod?
Pages:
Topic: Pump Mods/Gov Mod? (Read 7641 times)
Reply #15
June 06, 2007, 09:45:14 am
Pump Mods/Gov Mod?
Reply #15 on:
June 06, 2007, 09:45:14 am »
I believe you should only shim the main spring. I did just the intermediate spring, and although I haven't driven it yet, I don't like the way that you give it a little pedal and the rpm's start creeping up, then all of a sudden go way up.
Reply #16
June 06, 2007, 10:03:00 am
Bean
Pump Mods/Gov Mod?
Reply #16 on:
June 06, 2007, 10:03:00 am »
Is that on an N/A engine?
Can anybody else confirm this?
Reply #17
June 06, 2007, 07:12:41 pm
Pump Mods/Gov Mod?
Reply #17 on:
June 06, 2007, 07:12:41 pm »
It is on either engine. This is also what Named TinTin stated in another post, unfortunately after I did the intermediate mod.
Reply #18
June 07, 2007, 01:20:46 am
Bean
Pump Mods/Gov Mod?
Reply #18 on:
June 07, 2007, 01:20:46 am »
It can't be on either engine, because the gov mod guide for the turbo'd engines say to do both intermediate and main spring mods. And giles mentioned to only do one of the mods on the N/A engine. (If I understand correctly)
I just wanted to confirm if you were having these problems with an N/A or not.
So, how much am I shimming the main spring by, if that's the right one to do?
Reply #19
June 07, 2007, 04:15:13 am
foxracer1
Authorized Vendor
Pump Mods/Gov Mod?
Reply #19 on:
June 07, 2007, 04:15:13 am »
The reason you should only do one spring on a NA is the fact that it has no turbo and can't use all of the fuel. It just over fuels because the lack of boost.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #20
June 07, 2007, 05:43:12 am
Pump Mods/Gov Mod?
Reply #20 on:
June 07, 2007, 05:43:12 am »
Correct. And the reason Named TinTin states to not do it on the turbo is because it can cause driveability issues.
Pages:
Pump Mods/Gov Mod?
