Author Topic: I have a few problems with my 86 golf 1.6NA  (Read 4928 times)
November 10, 2006, 10:19:17 am
firestorm13666
  • 204
« on: November 10, 2006, 10:19:17 am »
Frist off i have a nice fuel leak on it.I replaced the front seal on IP but now the pump is leaking right where the pump body and block where fuel lines meet.What can i do about this?ALso my alt belt is still give me some problems.I think it is the alt pully it's self it ate away at the out side edge of the belt to where it would not longer seat right on the pully.I think it might be due to the fact the pully has rust on it.Thanks for any help
Reply #1November 12, 2006, 06:37:11 am
firestorm13666
  • 204
« Reply #1 on: November 12, 2006, 06:37:11 am »
Anyone?
Reply #2November 12, 2006, 07:18:37 am
« Reply #2 on: November 12, 2006, 07:18:37 am »
If you are brave there are seal kits available on ebay, as well as here http://www.emiata.com/DieselVW/
Try removing the belt and manually spinning the accesories, maybe one is partially siezed causing the belt to spin over it nd chewing it up?
Reply #3November 12, 2006, 08:58:41 am
« Reply #3 on: November 12, 2006, 08:58:41 am »
on my old 86 jetta i had to use a pry bar and give a good tug on the alternator... made it real nice and tight (maybe too tight... i dunno but at least the belt wouldn't be rubbing)
i think that year cars are prone to alt problems... could be the bracket?
Reply #4November 12, 2006, 02:29:41 pm
firestorm13666
  • 204
« Reply #4 on: November 12, 2006, 02:29:41 pm »
Thanks for the help.Well how much of the pump do i have to take apart to replace this seal and well where can i find the torq specs for it?Also so i need to take it off the car to replace it?That site is it a us or Can base and if so how do you order form it?Thanks
Reply #5November 14, 2006, 04:03:33 pm
firestorm13666
  • 204
« Reply #5 on: November 14, 2006, 04:03:33 pm »
Can anyone help me out?Also does anyone know where i can get the gasket set in the USA?Thanks
Reply #6November 14, 2006, 04:10:28 pm
« Reply #6 on: November 14, 2006, 04:10:28 pm »
I'm pretty sure that gasket set is from the us...
