Author Topic: inline pump on a TDI  (Read 8428 times)
October 23, 2006, 04:06:34 am
ruben
  • 14
« on: October 23, 2006, 04:06:34 am »
Hi all!
recently I read this topic
http://www.gardenpulling.nl/deelnemers/The Final Destination/deelnemer The Final Destination.htm
This guy has an inline pump on a TDI. Does anybody know if this can easily be done? What are the benefits from these pumps? One benefit could be you can drive on vegatable oil without pump probs.
Grtz,
Ruben
Reply #1October 23, 2006, 05:57:22 am
QuickTD
  • 1156
« Reply #1 on: October 23, 2006, 05:57:22 am »
If you take a look at the photo's you'll notice that the inline pump is taller than the valve cover. The tractor engine is mounted vertically, if the engine is leaned back 20º as it is in the car, the hood clearance issues become obvious. Aside from adding a "bump" for hood clearance you would need to build custom brackets, timing pulley, injection lines and you would need to modify the inline pump with heavier plunger springs, altered governor etc, to allow it to operate to 5000rpm. P-series inline pumps are rated no higher than 3000rpm. You would also have to put up with quite a bit of additional combustion noise. The inline pump has no provision for advancing timing with RPM, as most engines fitted with an inline pump have fairly limited RPM range. All the timing required for high rpm operation would have to be applied at all speeds, the diesel rattle would be quite loud.
 The advantage would be better operation with vegetable oil and better reliabilty at very high delivery volume, I can't think of any others.
Reply #2October 23, 2006, 05:05:26 pm
macsdub
  • 165
« Reply #2 on: October 23, 2006, 05:05:26 pm »
link not working for me :cry:
most of the time this is hilfolk'r... ive forgotten my password
Reply #3October 24, 2006, 03:18:13 am
ruben
  • 14
« Reply #3 on: October 24, 2006, 03:18:13 am »
hopefully now it will work
Does anybody know if there is a difference between inline turbo pumps and non-turbo pumps like on our pump the LDA?
Grtz
Reply #4October 24, 2006, 06:51:11 am
QuickTD
  • 1156
« Reply #4 on: October 24, 2006, 06:51:11 am »
Yes, turbo inline pumps have a boost enrichment system similar to the LDA on a rotary pump.
Reply #5October 26, 2006, 05:51:00 am
therabbittree
  • 299
« Reply #5 on: October 26, 2006, 05:51:00 am »
ah even that second link only showes the tractor running, the frame and the rear end...does any one have saved pics in case they changed the website?.. i am very interested
 also you can get the p pump engines to spin 7000 engine rpm buyt im sure they don't lasst forever that way but the pulling 5.9l cummins truck run about that rpm and 4500 is possible on a daily driver..so its a plasible pump infact ive been iching to try one ..just 5the drive system would need to be worked out..
thanks
deo
Reply #6October 26, 2006, 01:09:49 pm
hillfolk'r
  • 1532
« Reply #6 on: October 26, 2006, 01:09:49 pm »
yea i only rev my tdi-m to 4500-4700 you dont need more than that anyways
itll have siiick torque
hey deo,,,,im in ohio this week,ill be back wed/thurs
i nuked a trans on the arterial
blew 3rd right outta it
i found a 7A at A&T
and i got a ASF for 150 from waterbury,conn
i think ill put in the ASF for now,but the ultimate plan is to put the 3.67 from that box in the 7A
Throttle cables ftw
Reply #7November 30, 2006, 12:42:02 pm
Holeshot
  • 33
« Reply #7 on: November 30, 2006, 12:42:02 pm »
I'd also very much like to see some pics/video of this beast...
Thanks,
Matt
'94 Dodge Ram 2500 4x4 - 12-valve Cummins, NV5600 6spd, SBC Con FE clutch, EDM injectors, etc. ~400rwhp, Isspro EGT/100psi boost gauges
'98 VW NB TDI - not stock by any means, but still pretty tame.  TDI-M candidate :cool:
'00 VW Jetta TDI - wife's 300,000+mi daily driver
Reply #8November 30, 2006, 12:59:07 pm
Holeshot
  • 33
« Reply #8 on: November 30, 2006, 12:59:07 pm »
Here's a pic of a 1.9L TDI with what looks like an inline a-series style pump which the web page claims has 8mm plungers...
Custom intake/exhaust on another tractor...
Matt
Reply #9November 30, 2006, 03:26:06 pm
« Reply #9 on: November 30, 2006, 03:26:06 pm »
i like the idea of inline pumps, seem really cool to me, and i have also heard of the people that have the cummins and *** revving 7k, effing crazy
Reply #10November 30, 2006, 10:00:16 pm
hillfolk'r
  • 1532
« Reply #10 on: November 30, 2006, 10:00:16 pm »
yea and ive seen those sick tweaked  out  billet injector pumps get as pricey as 20k for a top of the world  total custom pump,ouch
Throttle cables ftw
