Author Topic: Max rpm on a 1.6td? [New mods coming]  (Read 6779 times)
Reply #15September 10, 2006, 08:16:04 pm
hillfolk'r
  • 1532
« Reply #15 on: September 10, 2006, 08:16:04 pm »
you know how your idle goes high like that?? yea its like that at hi revs with the gov mod
you can try moving the throttle lever 1 spline back,and then you will get some idle back,and/or be able to fuel more
sometimes moving it more than one spline makes throttle response lame
Throttle cables ftw
Reply #16September 11, 2006, 02:49:21 am
klang
  • 29
« Reply #16 on: September 11, 2006, 02:49:21 am »
Quote from: hillfolk'r
Okey, so with your inputs I dont think the gov mod is still in the picture...
So I remove the lever, move it one spline, wich direction should I move it?
And another question, I have to "bolts" on the pump, one in the front of the pump and one behind it.
the one behind it, adjusts the idle rpm, this bolt is now completly removed and the rpm is still to high.
The one in the front adjusts max lever position?
Is there any other adjustment to do on the idle rpm? (except for moving the lever one spline...)
regards
Klang
